Generator Light
Old Jan 12, 2006 | 11:35 AM
Steve's Avatar
Steve
Generator Light
I installed a GM three wire, internally regulated alternator in my '56 with 292. It works great. The funny part that I can't work out is that on initial start up, the generator light will stay on until rpms reach about 2,200 to 2,500 rpms at which point it will go off and stay off unless the rpms drop below 400 rpms or so. It really isn't a problem as I can make it go off by revving the engine once in the morning, but I am wondering about what is going on here. I don't think the alternator is at fault- is it the lamp itself?
Steve
Old Jan 12, 2006 | 01:24 PM
AXracer's Avatar
AXracer
altho an alternator does produce output at low RPMs, it is a relatively small current. I suspect it takes a higher current to trip your lite off than what it sees at idle.
Put an ammeter on the output wire and see what it's reading.
Old Jan 12, 2006 | 06:59 PM
57_ford's Avatar
57_ford
Is the light hooked to T1? it should be marked. Are you using the original truck wireing for the light?
