Gas guage delay
Old Jan 12, 2006 | 09:35 AM
Mango427's Avatar
Mango427
Gas guage delay
My 04 f-150 5.4L reg cab takes three days of a bit of driving before the gas guage comes up to the full end of the spectrum, after filling the tank. Whats weird is it used to come up immediately after turning the key off and then back on. Any ideas suggestions from anyone?
Old Jan 12, 2006 | 10:09 AM
fomocojoe101's Avatar
fomocojoe101
You answered your own question, Turn the switch off when refueling!
Old Jan 12, 2006 | 10:14 AM
Mango427's Avatar
Mango427
I do. I even take the keys out of the ignition, and it still does not come up for a few days
Old Jan 12, 2006 | 10:35 AM
fomocojoe101
OK, maybe you need to call ghostbusters! There is some info on refueling in your owners manuel, my 04 did the same thing, but it cleared up after resetting the onboard computer! (before you ask) Disconnect the negitive side of the battery, leave it disconnected for a few minutes, then reconnect, this will reset the onboard comp.
Old Jan 12, 2006 | 12:23 PM
CMOS's Avatar
CMOS
fomoco,
He needs to diconnect that NEG terminal much longer than just a few minutes. The internal cpaacitors in the PCM will hold a charge for a while.
I'd suggest an overnight disconnect.
CMOS
Old Jan 12, 2006 | 04:35 PM
zag's Avatar
zag
Wink
I don't know if this is your problem. In my 2000 150 I developed the same problem. In my case it was the fuel, contained to much sulfer which coated the sending units contacts. It made the gauge inside take a long time to respond. In my case, I changed fuel and added a bottle of red line fuel cleaner. It cleared mine up. This is a very big problem in later model corvettes. I hope this works for you.
Old Jan 12, 2006 | 04:36 PM
Mango427's Avatar
Mango427
thanks for a cheap easy suggestion ill try that tonight
Old Jan 12, 2006 | 04:46 PM
bobbylh's Avatar
bobbylh
It was stated in this forum a while back that it took 5 minutes to reset the pcm. I remember that because I suggested overnight also.
Old Jan 12, 2006 | 05:36 PM
derek4343's Avatar
derek4343
disconnect the negative side and turn your headlights on to drain the capacitors for about 30 minutes.
