Key won't turn
Old Jan 11, 2006 | 10:06 PM
w-3's Avatar
w-3
Question Key won't turn
I have an "88 F250, and after parking in the driveway today the key won't turn. I followed the suggestions in the alternate post for a Ranger to no avail, and it leads me to think that I need to replace the lock cyllinder. I've attempted jiggling the shift lever (automatic) while attempting to turn the key, and have also tried manipulating the key in the cyllinder while attempting to turn the mechanism. Let me know if I'm missing something. Thanks in advance!! www
Old Jan 12, 2006 | 02:18 AM
smecomark1's Avatar
smecomark1
It's probably jamed because of the steering wheel position, attempt to turn the steering wheel in the direction the wheels are pointed (taking pressure off the lock) at the same time turn the key. That should get you going
Old Jan 13, 2006 | 05:29 AM
mrmilkme's Avatar
mrmilkme
I Had The Same Problem On My 94 F350, I Towed A Trailer And A Fuse Blew ,i Could Not Get It To Start Or Put It In Gear ,so Take A Look At All Of Your Fuses Good Luck Let Me Know
Old Jan 13, 2006 | 06:58 AM
w-3's Avatar
w-3
Thanks for the info/advice. The problem turned out to be a bad lock cylinder, where the tumbler cover had dislodged and jammed the mechanism. I had a local locksmith come out - he had to drill the old one out - and he replaced it with an OEM cylinder. I'm back on the road again. www
