2wd ball joint replace
Old Jan 11, 2006 | 09:58 PM
Teo's Avatar
Teo
Question 2wd ball joint replace
Hello!
I'm new to this site, but finding it very helpful. I have a 1997 FORD E150 conversion van. I recently purchased new tires and was told at the tire store that I needed upper & lower ball joints replaced. The price tag was about $700.00. I went home jacked it up and checked it out. At a first glance it appears fairly simple, however I'm having a hard time finding detail drawings for parts and procedures. If anyone knows a good resource for these I could really use it. I noticed the passenger side seemed tight, but found a lot of play on drivers side upper. Question? Is there a bushing in the control arm (caster/camber) or is it a solid cast/forged and machined bore that the ball joint fits in. I'm wondering because the play seems to be more in the top (split) portion of the control arm. If anyone can help I would greatly appreciate it.
Thanks
Old Jan 13, 2006 | 06:48 PM
kynnhoj's Avatar
kynnhoj
Teo, Yes, there is a camber bushing (pre-set) in the upper bore of the I-beam. The job is pretty labor intensive, therefore the price is typically high. It is possible for a mechanically inclined person to tackle this work and save yourself some dough. Basically, you remove the wheel/tire,then the brake caliper, then rotor, then brake backing plate. Access to steering knuckle is wide open at this point, remove Knuckle via ball joints, replace ball joints and then re-assemble. It is not even necessary to have an alignment done unless it is known to be off in the first place or you have replaced any steering parts. Good luck, John
Old Jul 14, 2007 | 12:35 PM
otrf's Avatar
otrf
I followed the directions given above and removed the yoke off a 1994 E-150. But am having trouble figuring out which way the upper ball joint comes out of the yoke (Up or Down)?
Old Jul 14, 2007 | 01:02 PM
mhg's Avatar
mhg
top of page is, articles/specs
look up the article on replacing ball joints
very good write up
I do mine in the yard with a floor jack and jack stands
Old Jul 14, 2007 | 01:09 PM
kynnhoj's Avatar
kynnhoj
Both ball joints are pushed out from the knuckle to the "Up" side of the knuckle. Lower ball joint first then the upper. Installation is reverse, lower first, then upper. Good luck, john
Old Jul 16, 2007 | 09:08 AM
HHjr's Avatar
HHjr
PLease do what mhg recommends and read the article on how to do it. It is THE manual to follow. I just did my own on my 98 Club and saved $400. Oh, it was a project that took two people with breaker bars on the bj press. We even heated the knuckle on the lowers to get the ***** out.
There is indeed a pre set camber adjuster in the upper that has a tab that goes in between the pinch bolt. Easy.
Replace BOTH upper and Lower with new high quality part... MOOG. My CarQuest had them for for $47 upper and $41 lower.
Good Luck. Harold H.
lp92chateau
Feb 5, 2007 10:26 PM
lp92chateau
British Columbia
Nov 19, 2006 02:02 PM
77Fordf100
Mar 2, 2006 06:21 AM
terrapin88
25
Feb 15, 2006 06:08 PM
gandalf
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Dec 27, 2005 12:42 PM
