engine running rich, flooding - what's wrong?
Old Feb 24, 2006 | 10:36 PM
handsofpower's Avatar
handsofpower
need help finding a part for my truck
I'm looking for the thermactor air diverter (tad) and thermactor air bypass solenoid relay. I believe the ford part # is E4ZZ 9D474 E or # E4ZE 9. It has four vacuum ports on the undeside (two on the left and two on the right)
Does anyone know where I can get the above the mentioned item, preferably new?
Old Feb 24, 2006 | 10:38 PM
handsofpower
I'm looking for the thermactor air diverter (tad) and thermactor air bypass (tab) solenoid relay. I believe the ford part # is E4ZZ 9D474 E or # E4ZE 9. It has four vacuum ports on the undeside (two on the left and two on the right). It goes by the coffee tin thingy near the passenger side fender wall.
Old Jul 27, 2016 | 10:45 PM
vjsimone's Avatar
vjsimone
Did you ever finish this up?
Old Apr 30, 2017 | 09:52 PM
hawncase's Avatar
hawncase
That's the problem with this forum is that people share their problem, get advice from members and the guy that originally posted never shares back what happened?
I've been away from this forum for 5 years, even forgot I was a member, then had a problem with my 92 and have found a dozen threads that had similar problems and virtually all trailed off with no resolution.
C'mon guys, post back! It does no good to post your issues with no solution.
Old May 16, 2022 | 08:22 AM
Jason Heater's Avatar
Jason Heater
1st Gear
84 Ford F150 4.9l 4speed 4x4. Ecu controlled carburator.
So hopefully somebody will reply. My trucks been running to rich. I've replaced the vaccum lines plugs wires, cleaned the carburator. New fuel pump and filter. I have also punched the guts out of the catalytic converter. It still is running terrible. Anybody I would appreciate it thanks.
Old May 16, 2022 | 08:11 PM
vjsimone's Avatar
vjsimone
I suggest you start a new thread for your issue
lovethosefords
Oct 28, 2017 10:26 AM
Dustin_in_PDX
Oct 14, 2017 05:51 PM
2006powerstroke90
Apr 1, 2017 09:54 PM
BLUEOVAL1992
Jan 9, 2017 10:13 PM
Uncle Al
May 10, 2016 09:19 PM
