Dana 44 outers
Old Jan 11, 2006 | 07:41 PM
putzhall3's Avatar
putzhall3
Dana 44 outers
I was wondering if I could replace my spindles and brakes on my 78 F150 with ones from a 3/4 ton with a Dana 44. I would like the bolt pattern to be the same front and rear since I am planning on putting a Dana 70 in the rear. Less hassle only needing one spare!
Old Jan 11, 2006 | 09:24 PM
teds74ford's Avatar
teds74ford
Yes. I did that, using the spindles out. You don't need to swap the knuckles as long as you use the 5 lug spindles from ford. Chevy is different.
Old Jan 11, 2006 | 09:34 PM
surewhynot's Avatar
surewhynot
One thing to look at though is if you are running 15 inch rims. There will probably be clearance problems on the big dual piston calipers.
Old Jan 12, 2006 | 08:07 AM
putzhall3's Avatar
putzhall3
I am planning on running 16 or 16.5" rims with the Staun internal beadlock. So basically as long as I get the ford spindles and brakes for the f250 I will be okay?
Old Jan 13, 2006 | 07:55 AM
teds74ford's Avatar
teds74ford
Yeah, or you will need chevy knuckles to match the chevy spindles. I think ford is the only one that uses the 5 lug spindle. I used parts off a 79 F250 on a 77 F150 axle when I did my 4x4 conversion. Complete bolt on.
