CDR valve
Old Jan 11, 2006 | 03:56 PM
DeepDiver's Avatar
DeepDiver
CDR valve
After reading some of the other posts I decided to clean my cdr valve. I took off the air cleaner and there was this thing that lookes like some kind of canister, it had 2 bolts one on each side.When I got it off there was a hose on the bottom of it that went into the engine & another hole that connected to the air cleaner. Is this the CDR valve? Anyway, I couldn't see any way to take it apart to clean it. I just poured some gas in one of the holes and sloshed it around & then poured it out that other hole. The gas came out black. Did it 3 or 4 times until it looked better & then let it dry in the sun. Is this the way to clean it?
Old Jan 11, 2006 | 05:17 PM
Chevy_Eater's Avatar
Chevy_Eater
Yes to both questions.
