Bronco II Ford Bronco II
Turn Signal Switch?
Old Jan 11, 2006 | 01:38 PM
cjmedina's Avatar
cjmedina
Turn Signal Switch?
I have a 1988 Bronco II and my turn signal switch is broken.
The level is very loose. It just flops up and down. I Can only manualy force the rht side lights and if I go for the left signal I blow the stop light fuse
What do I need to fix it. Do I need to buy the whole assembly or just the cam .
Where can I buy what I need?
How much work is involved?
Thanks
CJ
Old Jan 11, 2006 | 07:46 PM
87 XLT's Avatar
87 XLT
Your Haynes manual will tell you how to replace the multifunction switch. It's a very simple 30 minute job.
The turn signal lever is part of the multifunction switch. About 50 bucks for the switch at Napa/Autozone etc.
Old Jan 25, 2006 | 07:41 PM
bandit990's Avatar
bandit990
im having a different problem but it requires me to go through the steering column. I looked through my haynes manual and all i saw was it said to remove the lever, i still cant figure out where the pin or screw is. anyone know?
