Strange noise, help please
Old Jan 11, 2006 | 06:33 AM
Robert6401's Avatar
Robert6401
Unhappy Strange noise, help please
OK, so Im going to do my best to describe what the noise sounds like, so bear with me. On acceleration I hear what sounds like small metal pieces being blown out of the exhaust, like a ******, *****, ******. Not everytime I accelerate, but probably 50-60% of the time, and not hard acceleration, I try to be light on the right foot for fuel mileage purposes. Truck is described in signature. Thanks in advance for the help.
Old Jan 11, 2006 | 08:10 AM
guzzle92's Avatar
guzzle92
Have you checked the bolts holding the turbo together. Some have a tendancy to loosen up and could cause the compressor wheel to come in contact with the housing. Due to the close tolerances, it wouldn't take much.
Old Jan 11, 2006 | 12:12 PM
qman's Avatar
qman
Don't know if this helps but I had an old Volvo that had somehow gotten a dent in the catalytic converter which broke the ceramic lining inside the darn thing. It made a funny noise but I can't remember what it sounded like. Hell, I don't even know if diesels have a catalytic converter. What kind of "Posting Guru" am I. I guess it just means I'm amazing at posting and has nothing to do with knowledge.
Old Jan 11, 2006 | 12:24 PM
Robert6401's Avatar
Robert6401
Some have cats, some don't, depends on where the vehicle was bought. Mine doesn't. Any other ideas? I will check the turbo compressor.
Old Jan 11, 2006 | 01:30 PM
Steve_250's Avatar
Steve_250
Have someone else try it while you listen outside. Hopefully you can narrow down the location of the noise.
Old Jan 11, 2006 | 03:30 PM
Robert6401's Avatar
Robert6401
only happens when moving that I have noticed. I have tried stomping on the pedal while in park and I dont hear anything.
Old Jan 11, 2006 | 03:40 PM
ggirten's Avatar
ggirten
If it only happens while moving, I would start looking at Ujoints. Driveshaft and front axles. Also make sure the brakes aren't down to the warning tabs. I've done that before.
Old Jan 11, 2006 | 05:52 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
do you a feel a loss in power or the sensation of the engine "slipping", not transferring the power to the wheels? may be a torque converter problem.
Old Jan 11, 2006 | 05:54 PM
SpringerPop's Avatar
SpringerPop
I'll bet "The Kid" is on to something, here. TC failure?
Robert,
Give us the circumstances when it started doing this.
Pop
Old Jan 11, 2006 | 06:02 PM
ggirten's Avatar
ggirten
I am going through that now. Was told it might be the TC, but the flexplate ended up breaking right around the bolts on the crank. I have the transmission out now and will be installing that this weekend.
Old Jan 11, 2006 | 06:29 PM
Kwikkordead's Avatar
Kwikkordead
Is the wastegate lever disconnected from the actuator and the arm flapping around?You would have quite a power loss along with it because of no boost. I've seen that on a Passat gasser once and it made the exact same noise that you describe. I thought it was the turbo wheel hitting the housing, it wasn't the case. The wastegate valve was flapping around from all the noise created by the exhaust pulses.
Old Jan 12, 2006 | 06:38 AM
Robert6401's Avatar
Robert6401
Well, all of this is good information, but I really don't feel a loss in power nor a feeling that the engine is slipping. It doesn't seem to affect the performance of the truck at all, its just an aggravating noise. It does seem to happen more often when the truck is cold and I haven't had the truck long but it has been doing it since I started driving it in November when I got home from Iraq. Thanks for all the help guys.
Old Jan 15, 2006 | 02:55 AM
JMoreland's Avatar
JMoreland
No Cat on 2001 and earlier Diesel Models
My manual says, "2001 and earlier models are not equipped with catalytic converters." Chilton: SD 1999-2002
