`95 4.9 Blues
Old Jan 10, 2006 | 11:36 PM
Redneck914's Avatar
Redneck914
`95 4.9 Blues
Hello , I own a 1995 F-150 with a 4.9 I6 Manual 5 speed, I want to swap out the 4.9 for a 5.8 from a lightning donor , I need to know if my tranny will bolt up to this engine or not. The lightning still has the auto trans in it but I think it would be more FUN WITH THE 5- SPEED................
Old Jan 11, 2006 | 01:49 PM
gatesj's Avatar
gatesj
4.9 has the same bolt pattern as any of the Windsor V8's. So yes, it will bolt up. The engine management will have to come from the donor. You will need a different flex plate or flywheel with the appropriate weight, your 4.9 is a balanced motor so it doesn't have a weight welded on there, the V8 needs one.
The problem comes in with the engine management though, the computer controls both motor and transmission in a truck with auto. If you slap a motor and computer in from a truck with manual into a truck with auto, the computer will not control the transmission and it will not work. There are standalone controllers for transmission in this case. What transmission do you have?
