i have a 93 ford f-250 2wd i6. it has not been driven in like 3 years and the shocks and leaf springs are rusted pretty badly. the question starts here. i probably need to replace both the shocks and the springs. i would also like a 2" - 2.5" suspension lift but don't have to have it. would it be cheaper to get a full suspension lift and replace it all or would it be better to just get replacement parts and perhaps get like a 2" body lift. are body lifts bad? i know very little about this so any suggestion is probably better than my guesses. also, where would be the best place to do my shopping? thanks for the help.
chris
i want to run 33's because i only have 3.55 gears. the truck is going to be a daily driver but i will occasionally be taking it off road...light off road and some trails, not the deeeeeep mud or anything like that
Ummmm I'd pry do a 2.5" or so suspension lift, swap out the 3.55s to 4.10s put in a good limited slip or locker, and run the 33s. Should be fairly capable then for a 2wd.
I would go for a suspension lift. In my opinion, its the "right" way to go. As with everything, there is a proper way and a cheap way. Now, before someone yells at me, I'm sure there are situations where a body lift would be prefered, but I would stick with the suspension lift. It will be more expensive though.
i have another question to add to the ones i have already asked. my stepdad bought this truck new in 93 from the dealer. the dealer sold it to him as an f-250 that has some 150 parts. is there a way to tell the difference between a 150 and 250 suspension and if so how? i need to know what type of truck to buy for.
if i get a small lift kit (2" - 2.5"): how much should i pay?
leveling kit: how much
what kind of shocks and how much?
thanks for everything. remember, not hard core offroading...just occasionally hitting some mud and trails.
y remember, not hard core offroading...just occasionally hitting some mud and trails.
There's a reason why most people use 4WD vehicles for these, especially for mud. In a 2WD truck most of the weight is on the front axle, yet the rear is the driven axle. That's not a big issue on solid surfaces, whatever they may be, but in mud or snow, that can be a 'sticky' issue.
If you are feeling really ambitious, you could always convert it to a 4x4
I did it to my 88, mainly because my mechanic told me I couldn't do, and I'm a stubborn person
You can have a lot of fun with a 4x2 and a locker, but you can have even more with a 4x4. It would be much easier to trade in and buy a 4x4 to build up though. More of your money could go into add ons.
i am building an engine for the one i have right now and i don't want 4x4 because of gas mileage. like i said, i am very rarely going to offroad it...if and when i do, i will have someone with me in another truck to pull me if i get stuck...i also am going to get a winch and mount it to a receiver to give me a tug if i have to. as long as i keep moving forward, i don't see too much of a problem. i wan't a small lift for the little extra room incase i come to a big bump, rock, whatever. this is why i was asking what i was...
small lift kit? how much?
shocks...what kind?
limited slip...how much?
not to be a you know what....but i wouldnt get all defensive when you come to the off-road and 4x4 forum asking questions about how to make your 2wd do what a 4x4 was designed to do, and the guys here tell you to get a 4x4
