curious about 3 valve heads!
Old Jan 10, 2006 | 10:43 PM
bigwobbely's Avatar
bigwobbely
the new explorer comes with 3 valve heads,and 292 h.p., i am curious as to if the heads will work on the 2005 4.6 motor. there is no reason that i can think of that would keep it from not working. any ideas ya'll??
Old Jan 11, 2006 | 05:52 PM
ctfordguy's Avatar
ctfordguy
If that motor only has 2 valves, then the cam is missing a lob for each cyclinder. Ford did make a 3v 4.6 in 2005. It makes 300 HP and sits in all the Mustang GTs, including a nice s/c Blue one in my garage.
Old Jan 11, 2006 | 05:53 PM
ford390gashog's Avatar
ford390gashog
he is talking about putting 3v heads on a 2005 4.6 2v in a truck
Old Jan 11, 2006 | 09:06 PM
bigwobbely's Avatar
bigwobbely
hey, ctfordguy! did you have to tweak the computer in any way for the heads to work right?(like as in trouble codes.) thanks!!
Old Jan 12, 2006 | 05:51 PM
ctfordguy's Avatar
ctfordguy
Bigwobbely,
I guess you mis understood me. Ford did indeed make the 4.6 with a 3 valve head in 2005. They put that engine in the Mustang GT, all Mustang GTs, so no I did not tweak the computer, Ford did at the factory.
Old Jan 12, 2006 | 05:52 PM
ford390gashog
the computers are different between the 2 and so are the wiring harnesses.
Old Jan 12, 2006 | 09:43 PM
bigwobbely's Avatar
bigwobbely
ct, was a big improvement over the 2 valve heads? i would assume it was plz let me know, after my warranty is out i want 2 do a few mods to my 2005 scab 4.6 thanks
Old Jan 13, 2006 | 12:33 AM
ford390gashog
how would he know?????? he has not done the swap nor has anyone else here.
Old Jan 13, 2006 | 02:47 AM
bigwobbely's Avatar
bigwobbely
if u take a look at ct's first reply he did indeed do the swap to his blue scab that sits in his garage. (or maybe i just read it wrong?)
Old Jan 13, 2006 | 02:52 AM
ford390gashog
you must have read it wrong. his has the 3v 5.4.
Old Jan 13, 2006 | 05:45 PM
ctfordguy's Avatar
ctfordguy
I have a 05 Mustang GT with a 4.6 3v that came with 3v heads from the factory. It is s/c(supercharged), blue and makes around 420 hp. I also have an 04 F150 with the 5.4 3v. It is not s/c but it is a scab and blue. Hope I am clear on this one.
Old Jan 13, 2006 | 11:05 PM
bigwobbely's Avatar
bigwobbely
yup, and thanks i was under the notion that you had put the 4.6 3 valve heads on your truck
