what engine??? engine help ???
Old Jan 10, 2006 | 10:08 PM
icuhatn99's Avatar
icuhatn99
I got this 75 f150 and the guy did'nt know what motor it was it has dove c on the side of the heads,7 bolts on the valve cover 3 on top 4 on the bottom,2 bbl carb....he thought it was a big block but was'nt sure any help would be great
Old Jan 11, 2006 | 12:59 AM
monsterbaby's Avatar
monsterbaby
Well based on the number of valve cover bolts, and the head casting number and the fact it has a 2bbl carb (assuming that it hasnt' been swapped onto the engine) that would most likely be a 70 or possibly a 71 (depending on block casting revision number) 429 passenger car engine.
Old Jan 11, 2006 | 08:38 AM
icuhatn99's Avatar
icuhatn99
thanks ....the bottom of the carb says 10.10.68 maybe this is a manufacture date??
