99 expedition door side moldings (help)
My 99 expy has the paint matched side molding with the chrome inserts and the chrome is faded and looks like it has water damage. I just want to replace the chrome strip in the middle, the plastic trim is fine. I have searched everywhere and can't find them. Does anyone know where I can get them or is there a way to fix this. Even if i could replace them in black, it would look better the the faded chrome ones. Thanks for any help
Originally Posted by PaulC
I've heard of Expy owners peeling the entire molding off to obtain a cleaner look. I don't recall anyone mentioning any mounting holes left exposed as a result.
Easy, just get a small flat tip screw driver, start at the end edge and carfully pry up the chrome stripping until you can get enough to pull it all the way off. Be careful when you pull it off not bend the stripping so that it does not crack. (this is easy, don't let it worry you). Then remove the old 3-d tape, clean both the stripping and the area where you removed the stripping with some type cleaner, I used "Goo be Gone" any walmart or lowes has it cheap. I then primered (paint) them, let the primer dry then painted them with gloss black auto or plastic paint. After they dry, I used a hair dryer to speed it up, re-apply with 3-D two sided automotive tape. Total cost $16.00, total time, not counting dry time, 1 hour....AND THEY LOOK GREAT! better than the factory job.
(1 spray can of black primer paint, 1 spray can of gloss plastic auto trim paint, 3 rolls of 3-D tape and a little time) You can get it all at walmart..
I just pulled off the chrome stipping which is inside the molding, so I can't say what the paint would look like under the molding. You can not just remove the chrome stipping and leave it that way because there are several holes behind the chrome stipping and it would look like sh... I believe you could remove the whole molding and the paint would probably be fine, but due to the age of the vehicle, I am pretty sure you would be able to see where the molding was no matter how much buffing and waing you do.
has anyone tried removing them
cleaing them up/sanding and then using a chrome paint instead of black. I have a lot of chrome on the expedition and im not sure if black would look good or not. I am also considering a stainless brush guard this summer and that might clash with the black. I know they make metallic silver spray cans but not sure about how long they shine.
