high CO2????
Old Jan 10, 2006 | 06:23 PM
ford390gashog's Avatar
ford390gashog
high CO2????
my buddy failed the cali smog test for the third time with his 351c. The test shows high CO2 what are the items that can be tuned and or replaced to fix this? we have decided to go ahead and get new cats, but is there anything else that should be checked.
mike
Old Jan 11, 2006 | 01:55 AM
Brian S's Avatar
Brian S
I didn't think CO2 was part of passing a CA smog test and I thought high CO2 readings were desirable. If the cat is working properly, I'd say lowering the CO level should also reduce CO2.
I have 2 well detailed smog articles scanned, 11 pages total.
I can send them via email if interested.
Old Jan 11, 2006 | 02:04 AM
ford390gashog
could you that would be great. i am pretty sure the test showed CO and CO2 but i don't have the sheet handy. but those pages would be awesome.
mike
Old Jan 11, 2006 | 04:17 PM
grclark351's Avatar
grclark351
has your buddy brought the vehicle to a shop that has a gas analyzer? they can adjust everything while reading the results and pretty much guarantee a pass. turning the screws without the equipment is like pissing into the wind in the dark. too much ignition advance will fill the exhaust pipe with HC's. IIRC too lean will send the CO reading off the scale? it's worth the price at the tune-up shop.
Old Jan 11, 2006 | 04:46 PM
ford390gashog
been to the tune up shops. all the ones out here are the legit type no one will adjust the car to any other specs than what the book says.so its been hard and frustrating
Old Jan 11, 2006 | 09:20 PM
grclark351's Avatar
grclark351
what did the shops say they could do? did they have a gas analyzer or just a timing light? if they worked on the vehicle and it failed they have some splainin to do.
Old Jan 11, 2006 | 10:58 PM
ford390gashog
yes they had a gas analyzer, but the shops will only turn it to stock specs.
Old Jan 12, 2006 | 12:38 AM
Brian S's Avatar
Brian S
If the Analyzer is tied into the State system I don't think it can fail 3Xs without causing some legal issues. Likely it was tested off-line first to see if it would pass.
I'm all in favor of clean air but I think for some, all the grief, anxiety and hardship caused by jumping through hoops for CARB does more damage to a person's health than the smog from their vehicles.
Old Jan 12, 2006 | 12:39 AM
ford390gashog
yes it is tied to the system. you must weigh it, enter vin and license plate each time.
Old Jan 12, 2006 | 01:11 AM
Brian S's Avatar
Brian S
At one time they weren't. Fortunately I haven't had to deal with all that crap in over 10 years. One of the advantages of driving nothing but pre '75 vehicles.
Old Jan 15, 2006 | 12:18 PM
Bill_Beyer's Avatar
Bill_Beyer
Wow, things have sure changed since I left the Republik of Kalifornia back in '90. At the dealership I worked in we just put the ol' HC probe in the tailpipe and adjusted what we could until we were sure it would pass before we ran the test.
What vehicle has a 351C that requires cats? Is there no longer a repair $ limit that allows any vehicle which has the correct, functioning smog equipment on it but still won't pass to be exempted by a referee?
jrocco
30
Jun 22, 2012 09:04 AM
jas88
May 15, 2012 06:06 PM
teddyu
Jun 28, 2007 02:11 AM
mxhowes1
3.0L V6
Oct 18, 2005 06:32 PM
20terminator03
Jul 27, 2004 01:43 PM
