I'm about to do something drastic
Old Jan 10, 2006 | 02:09 PM
LonW's Avatar
LonW
This is my second post looking for help with a fuel gauge (64 F100) sending unit. Brand new unit from LMC. Ground the hot lead and the gauge pins on full. Sit the sending unit on top of the tank (behind the seat) plug in the leads and I get a 3/4 reading (which would be fairly accurate). Put the unit in the tank and I get nothing. Float floats and rod moves easily in high-tech testing center (kitchen sink). Truck can be viewed in gallery under 'Fatmans Effie' if you need to be convinced she deserves your help. Would appreciate any tips, advice or Valium you can offer.
Old Jan 10, 2006 | 02:29 PM
Chevy_Eater's Avatar
Chevy_Eater
You're losing your ground at the fuel tank. Clean the ring clamp and the tabs on the fuel tank it comes in contact with. Check that the tank itself has a good ground.
Sorry, no Valium.
Old Jan 10, 2006 | 04:12 PM
gangstakr's Avatar
gangstakr
I would have to agree with chevy-eater your loosing ground, possibly the tank itself is not gettin good ground
Old Jan 10, 2006 | 05:06 PM
bertha66's Avatar
bertha66
If cleaning the clamg ring does not work, you can ground it to the body. My 66 F-100 had blade conection on the top of the sending unit to hook a ground to.
Old Jan 10, 2006 | 06:43 PM
phat56's Avatar
phat56
My '65 also has a separate ground. Be careful that you don't create any sparkage!!
Old Jan 10, 2006 | 06:48 PM
BobbyFord's Avatar
BobbyFord
I agree with everyone else. You should have two wires to your fuel sending unit. One should be the pulse wire (hot), the other should have a flat spade terminal (ground).
OHM check the ground wire. Sounds like it ain't grounded.
Old Jan 12, 2006 | 04:36 PM
LonW's Avatar
LonW
Okay guys, ready for this? This is the second sending unit from LMC. I sent the first one back as defective (they were really fast replacing it, by the way) after checking the truck's system, since it gave me no reading. The new unit came with what can be best described as a 'condom' for the float. With a full tank of gas, I lifted the sending unit just enough to see the float rod and determine that the float was NOT floating, even though it floated fine in water in the test lab. In desperation I removed the condom, replaced the unit and watched my gauge pin on full when I turned the key on. I have to run out some gas to see if I get anything else but a full reading and the suspense is killing me, but I'll keep you posted. Anybody know what purpose the 'condom' is supposed to serve?
Old Jan 12, 2006 | 04:53 PM
Redmanbob's Avatar
Redmanbob
I'm going to go out on a limb here and say it's a moisture preventive for the cork. But these days heck you can never be too careful !!!
Old Jan 12, 2006 | 07:00 PM
BobbyFord's Avatar
BobbyFord
I think the "condom" is for anti-rattle. I think at some point the float comes close to the tank side.
The sending unit is still available from Ford. (1977 part #).
Old Jan 18, 2006 | 01:37 PM
LonW's Avatar
LonW
The fuel sending unit works! Thanks to everybody for the posts, hints, and tips. I still don't know why with the 'condom' on the float would float in water but not gasoline, but at my age I'm happy to let life's mysteries remain mysteries. Thanks again, guys.
