Yikes!! Melting Ignition Module??.....
Old Sep 30, 2001 | 04:44 PM
cigarxtc's Avatar
cigarxtc
I have a 78 F150 2wd automatic w/ 351m(or 400). The ignition module metal housing is intact, and the wiring and connetors are ok, but the see thru wax type backing is melting onto my inner fenders. What causes this stuff to melt out? Does it mean I need a new Ignition Module?
Old Sep 30, 2001 | 05:05 PM
Db3frdlvr's Avatar
Db3frdlvr
Where are you located at? Down here in Oklahoma That glue melts out of modules on a regular basis! Especially if the module is mounted on it's side. Then it procedes to run down the inner fender making a real mess! All of the ones I have that are mounted on their side lost all of their "stuff" years ago, but have not failed yet.
Dex.
Old Sep 30, 2001 | 06:32 PM
fordmaniac21's Avatar
fordmaniac21
hey my 75 does the same thing. everything seems to be workin just fine lol imagine that. typical ford thing yeah it may look broke but she still works like a champ
Paul E Goodman III
'75 FORD F-100 4x4
390 4 barrel edlebrock, high-rise manifold, comp cam
16/38.5x15 super swamper TSL
Old Sep 30, 2001 | 09:50 PM
cigarxtc's Avatar
cigarxtc
Hmmmm....It should still work, huh? I'm in Owasso, Oklahoma. I noticed the leak this weekend while troubleshooting a sputtering problem with my engine. My truck has sputtered to a stop 3 times in the last three weeks. Each time, I was sitting at a stop light or sign for a few minutes and then when taking off the truck sputters and dies. After the first time I replaced the carb w/ a rebuilt 2bbl motorcraft. It sputtered to a halt twice with the new carb. Here's the list of all I've done to cure this problem. Have I missed checking anything else?
-New Carb
-New fuel filter
-New Fuel pump
-New Taylor 8mm wires
-New Accel 8140C coil
-Timing set to 12degrees btdc
-carb tuned to constant 19lbs suction
-water remover treatment with each tank of gas
-New Air filter
I was wondering if the ignition module melting backing could be a cause?
Old Sep 30, 2001 | 10:03 PM
MattD's Avatar
MattD
I ve never heard of the glue melting in an Ign module. I live in Louisiana and it gets HOT here in the summer! I would get another module, they arent too expensive at Auto Zone. Also check the wiring harness from the Ign switch to the coil. I had the wire from my ign switch to my coil pull halfway out and anytime the motor moved a certian way the motor would die. I fixed the wire and it fixed my problem!
Good Luck!
Matt
1978 F100 Custom
320 horsepower 302
C6, 9 inch
Ford Motorsports E303 cam
GT 40 P heads
Crane roller rockers
Weiand Stealth Intake
Edelbrock 600 cfm carb
full length headers
More mods to come!
Old Oct 5, 2001 | 01:12 PM
cigarxtc's Avatar
cigarxtc
I spoke with a Borg-Warner Automotive engineer over the phone today. They have two different Ignition Control Modules for my truck. The CBE7P or CBE7. The P one is a stock replacement, and the CBE7 is a better grade replacement. I told him about the melting backing on the original module, and he said that would be caused by a bad resistor wire on the coil, or by having too low of a resistance on the primary. I'm not quite sure what that means, and he didn't have more time to talk. Are there any Ignition Module Experts on this forum?
Old Oct 5, 2001 | 01:45 PM
85351ho's Avatar
85351ho
DrZoom
Aug 5, 2016 12:57 PM
jstsumgi
Sep 14, 2015 08:57 AM
74FamilyTruck
15
Apr 21, 2012 12:35 PM
69CamaroL34
Oct 26, 2010 09:02 AM
padlikehel
Mar 19, 2010 07:57 AM
