Sponsored by: Real Truck
Grinding noise ?
Old Jan 10, 2006 | 08:42 AM
XxfirmanxX's Avatar
XxfirmanxX
Question Grinding noise ?
I have a 04 F250 6.0 diesel 4x4 when I make a left hand turn my front tire sounds like is grinding I have looked at the tire for rubbing not that. Thought it might be a bearing has any one had or exsperenced a problem like this.
Old Jan 10, 2006 | 08:21 PM
99f350sd's Avatar
99f350sd
Check the hub staying locked see if the axle is turning in 2wd. You may have a bad bearing. Jack it up and see if there's any play in the bearing.
Dick
