Bronco II Ford Bronco II
Dash light question
Old Jan 9, 2006 | 02:50 PM
Bgrossenbacher's Avatar
Bgrossenbacher
Dash light question
We replaced the dash in our 90 with an explorer dash from a 93. Used the wiring, AC controls and gauges from the BII. Everything went together and all the plugs seemed to fit. The BII runs fine and the replacement looks much better than the old torn up one it replaced
now the tach and gauge lights do not seem to work, any ideas on what my teenage son and I can check to get the tach working again? Do we just need to pull the guages again and replace all of the lights?
thanks
Old Jan 11, 2006 | 07:44 PM
Ken00's Avatar
Ken00
If the bulbs looked good before you installed it I would suspect a wiring issue, double check your connections.
