need distributor - rotor alignment ?help?
Old Jan 9, 2006 | 03:51 PM
riley3d's Avatar
riley3d
Question need distributor - rotor alignment ?help?
I took out my single vac adv. distributor and free'd up the vac advance plate (which was stuck). I marked the distributor placement, but forgot to note which way the rotor pointed. Since I have tried to start it. I was a VW guy and figure there is a certain way it should point with the engine at TDC, just don't know if there is a mark or not. Thanks for the quick answer, as I am trying to get it back on before dark.
Old Jan 9, 2006 | 05:16 PM
riley3d's Avatar
riley3d
OK - got it running, but dont have a timing light, any tips. I have been moving it back and forth going with what sounds best. It is backfiring out of the carb - too advanced? Advancing is turning dist. clockwise-right?
Old Jan 9, 2006 | 05:48 PM
grclark351's Avatar
grclark351
yup, advance is clockwise. do you know anyone with a timing light? with the engine at #1 TDC, the rotor should be pointing to about the 1:00 position and the advance can should be pointing about straight forward(6:00 position).
Old Jan 13, 2006 | 12:29 PM
fastford59's Avatar
fastford59
point vac advance to front of motor and rotor button towards #1(1st cylinder on right) with piston on compression stroke.That should get you in the ball park...
.:1978_Ranger:.
Jun 19, 2024 09:17 AM
btacarlton
28
Apr 17, 2009 09:40 AM
ErrorS
Nov 7, 2007 07:04 AM
msteelsos
Feb 21, 2007 09:29 AM
jwxb41b
Apr 11, 2002 09:12 PM
