Air Shocks?
Old Jan 9, 2006 | 03:16 PM
Redmanbob's Avatar
Redmanbob
Air Shocks?
I wanted some advice on a set, I have no one with them in stock... but a coupla choices.. Auto Zone: Gabriel 49127 or Napa: Monroe but no part #
anybody have an opinion, warning ?
Old Jan 9, 2006 | 03:58 PM
garbz2's Avatar
garbz2
Red you are not from Eastern PA are ya......Air Shocks and white painted rears are something we have been trying to live down for years...LOL
Is the application you are looking for overloading or just cool?
Garbz
Old Jan 9, 2006 | 04:03 PM
Redmanbob's Avatar
Redmanbob
Camper 700 -900lb loaded maybe and towing a boat 1500-1800lb depending on bilge water LOL
Old Jan 9, 2006 | 04:27 PM
garbz2's Avatar
garbz2
I would not recommend air shocks. they have a tendency to blow the seals and leave you hanging in the middle of bumville with no shock or support.
I would check into a set of firestone overload bags that can be inflated based on the load. and deflated to a reasonable level when not hauling a load.
They basically attach to the axle tube and frame.
This leaves the shock to pull the dampening duty they were intended for. A good set of Monroe Gas Magnums will do the shock duty.
Thats my opinion.
Garbz
Old Jan 9, 2006 | 04:36 PM
Redmanbob's Avatar
Redmanbob
Thanks Garbz that is why I ask: I'd not thought of the stranded situation only the weight, brand name issue
Old Jan 9, 2006 | 06:50 PM
hiball3985's Avatar
hiball3985
I'm not crazy about air shocks for increasing load capacity.. you would be better off with heaveir springs..but if you have to, go with the gabreil..monroes are crap..IMHO
Jim
Old Jan 9, 2006 | 06:55 PM
jd_sylvia's Avatar
jd_sylvia
The air bags are great and probably a better than air shocks.
I have installed several set of Gabriels and have never had a failure. They are a bit of a hassel because you seem to forget to ad air go to get lumber and there is never air so you want to remember add air before you add the load or have a air tank handy. Also watch were you run the lines keep clear of pinch points and exhaust.
I have a set on my commuter truck and they do come in hady and have a smoother ride than over loads.
good luck
jd
Old Jan 10, 2006 | 06:01 AM
jowilker's Avatar
jowilker
JD, Maybe adding a compressor to your truck using an old York AC compressor would be helpful for that.
I know where a tech article is for doing that.
John
Old Jan 10, 2006 | 08:13 AM
jd_sylvia's Avatar
jd_sylvia
They make a little compressor kit you can add on, but I don't use them enough to justify buying it. But the York compressor would be nice just to have air... If you come across the article let me know.
My brother built one once from an old Ford A/C compressor and he used to run air horns off of it, plus a 10 gallon air tank under the truck for reserve.
jd
Old Jan 10, 2006 | 09:24 AM
Redmanbob's Avatar
Redmanbob
Seems I can remember my uncle using his AC compressor in an emergency once but my mind is getting a bit woosey these days.
Old Jan 10, 2006 | 09:49 AM
jd_sylvia's Avatar
jd_sylvia
Ahhhhhhhhhhh to much work and not enough fishing.....
jd
