high speed whistle
I posted the same concerns on my '05 F150 Lariat a few months ago. The dealer told me that this was normal, and I told him to fix it. They lowered the headliner, and put in sealer at the leading edge with no luck. As per others, certain days has louder noise due to the wind direction and wind speed, and this noise increases from 45mph up . It sounds like the top of the windshield , but also from the base of the windshield. Very annoying. My friend has a '04 Lariat with a lot less wind noise. Mirrors are not the issue, nor is the bug shield, as this truck was noisy since day one . That story about the rest of the truck being so quiet doesn't have anything to do with it, believe me! Maybe it is the noise from the cowl/engine compartment? Anybody have other suggestions? It would be nice to fix this, as more people have this issue than some realize.Thanks
Dave Christo
Dave Christo
i had mine back at the dealer 7 times
change the windshield twice
still no luck, and dealer to me is normal, (funny)
so i took it to the lemon law
is in the process now, almost been a year
you guys should save all the service order and file a lemon law against ford
thanks
Now when I first took the truck in last May for the noise, I informed them that I put the bug shield on and also swapped the antennae for garage fit. They said they would be more than happy to look at the truck, but if they found out that it was 1 of the 2 none stock items, it would not be covered by warranty...OK. So I took the bug shield off and put the stock antennae back on and took it in, still whistling....Go figure.
When I was talking to the ServMgr about the issue, he said he remembered going for a ride with me last May with everything stock and even remembered why I had a different antennae. My theory is that the 3 previous times the truck was in and they did everything they could to the windshield area without replacing it, they fixed something and we were dealing with 2 different, possibly related issues.?.? It sure seemed like the whistle got louder between messing with the windshield and finding the antennae issue.
So long story longer, I grabbed the OEM antennae, cut it to fit, and there is no more whistle. I owe the service dept big time for this one as they could have dinged me in the pocket book, but were very good sports about the whole thing.
Windshield wipers...
I removed them last weekend and magically, the sound is gone.
Last time it was at the dealer they checked the noise and said they could not hear it...
It would appear my passenger side wiper is deformed. The top of the frame is bent outward and up.
I will show it to the dealer next time I'm in and have them replace it...
The first thing I did was search online where I found and read through all the topics on the subject but haven't seen any clear answers as to what the problem is.
I then contacted Ford directly (via online form) but they told me to go see the dealer (even though I told them that no customers experiencing the problem were helped by their dealer). So I plan to go to my dealer soon and start the complain process.
I decided to do some investigating of my own as to the cause before I take it in so I bought some masking tape over at HD (make sure it is NOT the strong adhesive kind! I used the low adhesive kind and still had residual glue in some places that I had to clean with WD40) and taped up various sections that I thought could be causing the whistle. I tried one section at a time, mostly concentrating on upper passenger side as that is were the sound seems to be coming from. I swear I used half a roll of tape and STILL couldn't get the noise to stop. I even added tape to the antenna to no avail. I also removed the wipers. Still whistle was present. So I'm just letting everyone know that I'm also having this problem and would love to hear if anyone has definitively solved it and what the remedy is. I'm taking mind into the dealer next week however I'm not hopeful they will be able to solve it.
Click here to watch dyno-pull-89
http://media.putfile.com/smoken-f-150
Ford: "well, we think it is bolted on to the roof and we can't remove it. You need to take it to a body shop"
Me: "But you said that adding it disrupted the natural flow of air across the roof. so you guys should fix it"
Ford: "Well we don't install it, Ford does before they send the car to us"
Me: (thinking that isn't entire factual, probably some aftermarket firm contracted by Ford, but anyway)
Ford (continues): "Oh and btw, I (service rep) drop it around and didn't hear the whistle"
Me: "Yeah but you said your techs DID hear it earlier when they tested it, right?"
Ford: "Oh yeah, I guess I wasn't driving fast enough... there was a lot of traffic. Why don't you come down and drive another one. Probably all of them with the sat. anntena do the same thing."
Me: "What difference does it make? And besides, I doubt they all do as only a segment of users are/is complaining about it. Probably has to do with exact positioning of the antenna."
I was getting no where with the service guy so I went in later that night and talked to the manager of the service area. He was much more understanding (and sympathetic) of my problem. He didn't believe that the antenna couldn't be moved and said that even if they had to take it off they could probably seal up the holes pretty good. He then asked me to contact his main radio tech today and follow-up with him. I'll keep everyone posted on what happens.
The horrifying thing about all this is what if it ISN'T the antenna? What if i move it somewhere else or get dir of it completly and STILL have the whistle/whinning sound at speeds? THen what?
Quick Poll: How many of you that posted about this whistle/noise have or don't have the satellite antenna dohicky mounted to their roof?
