Air filter electronics
Old Jan 8, 2006 | 11:20 PM
Garyinreno's Avatar
Garyinreno
I want to go to an after market air filter without the box that is stock---Three problems.
Two vacuum hoses go into that box in the rear of it, and an electronic wiring harness plugs into the black plastic assembly....How do i go to an after market filter like a K/N and still have the vacuum hoses, and wiring harness, which when i unplug makes the check engine light stay on. I'd like to upgrade but sometimes it's hard.
Thanks All
Old Jan 8, 2006 | 11:51 PM
dono's Avatar
dono
Gone but not forgotten.
You didn't tell us the model or engine size of your truck so an answer is difficult. I don't know of any vacuum lines or electronics associated with the airbox on most Rangers. Ford, in it's infinite wisdom, moved the MAS from the air tube to the top of the air box on my '04, maybe that's the plug you describe. I had a large air tube with a big K&N cone on my '99 and noticed very little difference from stock.
Dono
Old Jan 9, 2006 | 06:29 PM
Garyinreno's Avatar
Garyinreno
It's a 1991 ranger xlt super cab v6 4.0 there are two vacuum hoses going into the back of filter box. There is also a electronic plug that plugs into an aluminum cap just befor eth box--which if i unplug my check engine light comes on. There is also a oil cooler hose that comes off the area to the oil filler cap. How do i get around these to go to a after market air like a K/N or other full around air filter right off the engines air intake.
Old Jan 9, 2006 | 07:40 PM
Peter94's Avatar
Peter94
check out www.ifab.net i bought my intake from there. They just said to plug the 2 vacumme lines, and mine didnt have the electric wires going to it, but i'm assuming those are for you IAT sensor, and you can just relocate that somewhere else in the intake.
Old Jan 9, 2006 | 07:55 PM
Garyinreno's Avatar
Garyinreno
That's the exact air filter i wanted and it even shows the electronics on it, thanks alot
Old Jan 9, 2006 | 08:00 PM
Peter94's Avatar
Peter94
lol, i actually took it off of my ranger and installed it on my 85 F150 when i did my MAF conversion, i have pics in my gallery, lol
Aetic
15
May 17, 2014 09:48 PM
Van Diemen
May 14, 2014 10:12 PM
Mr Dave73
1997 - 2003 F150
Nov 27, 2010 01:41 PM
ibuzzard
13
Sep 7, 2010 10:10 PM
case2k5
Modular V8 (4.6L, 5.4L)
Sep 18, 2005 05:20 PM
