PSD won't start after swap
Swapped a 97 psd into a 93 f250. Took all wiring with the diesel, under dash and under hood harnesses. Replaced PCM, swapped gas tanks, all lines and all electronics. Changed the fuel filter and oil filter. Anywho i go to start it and key in the on position i hear a buzzing from the fuse box under the hood. I thought this was the self-priming fuel pump but when i check the filter its still bone dry. So i add diesel to the filter bowl. Still nothing. Cranks and cranks but no start. Oh and the truck was sitting 7 months before i bought it. Help?
You might have noticed, having installed the engine and presumably the fuel system, that there is no "self-priming" fuel pump. If the filter is dry after cranking it, the fuel pump is not working, or you have the fuel lines connected incorrectly. That would be the first thing to check.
Nothing in the fuse box should buzz. It's just fuses and relays. Any noise like that suggests a voltage problem as mentioned above. Try disconnecting the GP relay and turning the key to RUN, just to see if that makes the noise stop. If so, it's def. a voltage problem.
Other preliminaries - does the WTS light come on (you DID swap in the diesel-specific cluster and lights, right?)? Does the tach move when you crank it?
