Dana 44 HD
Old Oct 8, 2001 | 05:10 PM
petem's Avatar
petem
Dana 44 HD
How do you tell if a front axle is Heavy Duty?
Old Oct 8, 2001 | 06:34 PM
mattyk6's Avatar
mattyk6
Dana 44 HD
As far as I know, the 4wd locking hub is larger than most. It is kinda hard to explain, you just kinda know. Also, as far as I know, they only came on Highboys. Could be wrong.
I am sure that others have better explanations.
Good Luck!
Matt
1974 F-250 4x4 Highboy
Old Oct 8, 2001 | 08:54 PM
toyshop's Avatar
toyshop
Dana 44 HD
I was led to believe the standard duty "44" axle had conventional press in ball joints; the HD "60" axle had bolted caps where the ball joints were. Other than that, I would hate to mislead anyone. Hope this helps.
Old Oct 8, 2001 | 09:01 PM
alpo23's Avatar
alpo23
Dana 44 HD
The HD dana 44 in the F-250 has what is called an 'external locking hub'. The regular hub is retained by 6 small socket head cap screws. the threads of these screws is about 10-32-UNF. the HD hub is held in place by six large Socket head cap screws. these threads are about 3/8-16-UNC. this a big two-piece assembly. the HD hub is about 4 1/2" in diameter while the standerd one is only about 2 5/8". Hope this helps some.
Eric
Proud owner of a '73 F-250 4x4 High Boy, 460 V8, NP435, NP205, Dana 60 rear w/Detroit Locker
And a '68 Bronco 289 v8 , NP435 , Dana 20
Old Oct 8, 2001 | 09:09 PM
DirtySideDown's Avatar
DirtySideDown
Dana 44 HD
All Dana axles have the series, 30...44...60...70...ect cast into the re-enforcing web from the axle tube to the pumkin.
DSD
Old Oct 9, 2001 | 03:05 AM
cjohummer's Avatar
cjohummer
Dana 44 HD
If you find out you don't have one, don't be sad. make yourself happy and get the king of front axles, a dana 60. but be forwarned, on the subject of heavy 44's some of the early to mid-70's crew cabs had a dana 60 3rd member with 44 axles and tubes and large closed steering knuckles. be sure to steer clear of these.
Old Oct 9, 2001 | 07:20 AM
chilly390's Avatar
chilly390
Dana 44 HD
You're partially correct. I have a '76 Dana60 front with the parts as you described, but it has OPEN knuckles. Sneaky. I bought this before I really knew how to spot the good 78/79 d60's and obviously was disappointed with the d44 axles.
Old Oct 9, 2001 | 01:01 PM
petem's Avatar
petem
Dana 44 HD
Thanks for the information. My hubs are auto-locking, so I'm not sure if those were available in HD form. My front axle code is: J.
Thanks again for all the responses!
Old Oct 10, 2001 | 12:57 PM
cjohummer's Avatar
cjohummer
Dana 44 HD
This is for the guy with the 76 dana 60. I must ask if it has the large king pin caps, or the small ball joints like the 44. Is it reverse rotation? Once I saw a Ford (left hand side diff) front end that had disc brakes, open knuckles, but had standard gear rotation and wondered what the hell it was. Maybe it was what you have?
Old Oct 12, 2001 | 11:05 AM
chilly390's Avatar
chilly390
Dana 44 HD
It is a kingpin frontend, open knuckle, 19 spline outers, and it is NOT reverse rotation. Very weird. Oh well, live and learn. I picked it up for $400 so it wasn't too bad. In '76 they put these frontends in Crew Cabs. Warn actually still makes hubs for them, I had to get a pair. The hubs are sort of cone shaped with six bolts holding the locking hub to the hub body. Not the same as the big ones used on later HD 44's and d60's.
Old Oct 12, 2001 | 03:56 PM
Supercab's Avatar
Supercab
Dana 44 HD
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
