Steering Fibre Disc Needs Changing
Old Jan 8, 2006 | 04:00 PM
MAX68's Avatar
MAX68
Question Steering Fibre Disc Needs Changing
Can Anyone Tell Me How To Easily Change A Manual Steering Fibre Disc-two Bolt Type. Can You Change This To A 4 Bolt Type , For F100-68
Thanks Max68
Old Jan 9, 2006 | 01:41 AM
bob arrington's Avatar
bob arrington
depending on weather it is towards the grill or back next to the firewall it is either easy or a pain and you are better with the two bolt , bob
Old Jan 9, 2006 | 06:37 PM
MAX68's Avatar
MAX68
Bobbbbbbbbbbb
Do You Know The Procedure For The One At The Fire Wall
This Is A Two Wheel Drive
Old Jan 9, 2006 | 08:34 PM
bob arrington
the only thing really different is that the firewall one is a pain to get to , basicly you just remove the two bolts in the rag , remove the keeper cross bolt, and sometimes you have to drop the steering collum so it will slide back far enough to slide the rag joint off , rust loosener is a good thing , bob
Old Jan 10, 2006 | 03:35 PM
ramtoo's Avatar
ramtoo
is this also called a rag joint
Old Jan 10, 2006 | 08:22 PM
MAX68's Avatar
MAX68
thanks fellas. i'll try it next week
Old Jan 16, 2006 | 04:05 PM
bob arrington
it is if fact , called a rag joint , bob
Northern Econoline
Aug 1, 2013 10:40 PM
AllaboutMPG
Jan 30, 2012 10:04 AM
Para045
17
Feb 28, 2008 06:16 AM
low428
Jan 20, 2002 01:57 PM
