spools- where's the best priced!
been hanging around for a while & learning alot but now I need alittle info on the best place(price) to get spools. I plan on a gear swap & while I'm in there I want to add spools. I figure you all have the info I need or can direct me to the right source, any & all direction will be helpfull. Thanks in advance
paqmaster
What about just welding the whole thing together? Contrary to popular belief ,if you are carefull and use lots of rod it can be plenty strong. I welded a Dana 44 up on the front of a truck which has low gearing, 35s, and is used for hard core off roading, with no problems. It has held up through almost a year of abuse.
