Valve Stem Seal Question
Old Jan 8, 2006 | 12:04 AM
hawaiifordfan's Avatar
hawaiifordfan
Question Valve Stem Seal Question
Not sure if this is the right place for this or not, but worth a try right. I bought a gasket replacement set for a 93 Ranger 3.0 V6. Everything was fine until I got to the valve stem seals. They are supposed to be marked (they aren't), 6 are brass and 6 are silver. Does anyone know which goes on the intake and which on the exhaust?
Thanks!!
Old Jan 8, 2006 | 01:35 AM
ford390gashog's Avatar
ford390gashog
those don't sound like seals but rather guides.
Old Jan 8, 2006 | 06:18 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved to proper forum
Old Jan 8, 2006 | 09:05 AM
hawaiifordfan
They are valve stem alright but there rubber caps with the bands around them to keep them tight and the ones i took off were marked but these new ones are not and i dont want to take a chance on screwing up any ideas.
Old Jan 8, 2006 | 12:10 PM
03XLT4x4 Flareside's Avatar
03XLT4x4 Flareside
Those valve stem seals are different heat temp--intake & exhaust. Depending on the gasket manufactuer, there should have been a note in there describing the difference. Sometimes they will have a "IN" or "Exh" marking on top of the seals, others ID them by the color of the band (in your case). One way you could find out, if your not sure, would be to pick up either a set of exhaust or intake seals[of the same gasket man.] & see what color those are.
Old Jan 8, 2006 | 05:23 PM
Bart99GT's Avatar
Bart99GT
With most new valve seals, it really doesn't matter which valves they're installed on. The older all rubber seals were made out of slightly different material for the exhaust side, though it didn't seem to matter much, they'd still get too hot, dry up, and then start to leak.
96ford250
Jan 25, 2011 11:23 PM
safetysandy2
Apr 20, 2010 03:24 PM
Mr Personality
Dec 4, 2002 11:52 PM
mchild
Oct 28, 2002 02:38 PM
GeneStoner
Oct 23, 2002 03:25 PM
