Hey guys, a friend has an 86 F150 2wd truck, 302 EFI. He tore up the crank. I have a couple of 302's. One is in an 84 LTD Wagon, with the CFI fuel injection, and then some old 302's. I figure the older style crank won't work, but will the crank from the CFI engine work as a direct bolt in? If they decide to just swap engines, can they use the 302 CFI block and bolt the EFI stuff (heads, etc..) from the 86 truck?
Off the top of my head a couple of things come to mind. First off, when yo say old 302, how old are we talking? A pre-1981 crank won't work for two reasons: one is that the factory imbalance is 28oz instead of the '81 and newer 50oz imbalance, and the other reason is that they also changed to the one-piece rear main seal at the same time.
So let's take a closer look at that '84. That engine should have the crank trigger ignition which has a sensor ring with 4 lobes on the rear of the crank. I don't believe that will cause an interference problem with anything on the later block, so it should be a traight bolt-in swap.
I also don't see a problem with going the other way, bolting all the '86 EFI stuff onto the '84 block.
