Bronco II Ford Bronco II
3.0?
Old Jan 7, 2006 | 07:30 PM
bronocIInoob's Avatar
bronocIInoob
3.0?
i think ford started making the 3.0 engine instead of the 2.9 in the ford ranger in 1990 dose this mean a 1990 ford bronco II has a 3.0 being that it has the same 2.9 the ranger had the option of for all the other years or did they just keep the 2.9 till 1991 when it was replaced by the 4.0 ford explorer
Old Jan 7, 2006 | 08:03 PM
Mudder's Avatar
Mudder
The broncoII had the 2.9 right to the end of production.
Old Jan 8, 2006 | 07:28 PM
oppy's Avatar
oppy
Correct!
Also, the 4.0 replaced the 2.9, not the 3.0.
Old Jan 9, 2006 | 05:39 PM
bronocIInoob
yes in the bronco but after 1990 the 2.9 engine itself which was used in both the bronco II and ranger was replaced with a 3.0 although the bronco II was no longer made the engine that it had was still in production for an engine option in the ford ranger and was remade from a 2.9 to a 3.0 back when bronco II's where made with the 2.9's engines that same engine was available as a choice in the ford ranger so if you hade the 2.9 v6 engine in your ranger you basically had a bronco II pick up
mrka.davidson
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 22, 2015 09:05 PM
1990-f250
1983 - 2012 Ranger & B-Series
Sep 14, 2014 10:29 PM
pmibach
Sep 6, 2014 10:01 AM
