cold start problem???
Old Jan 7, 2006 | 07:21 PM
stevcher's Avatar
stevcher
I have a 1992 f150 5.8.If it get cold outside below say 20 degrees when I try
to start truck turn switch to on listen for feul pump it will start on not shut down which is when I have problem with no start.When temp raises I can turn switch on and pump will start for approx 2 sec and truck will start.I have tried dry gas which I thought worked but last night droppped to 0 and geuss what
truck did no start with pump not stopping.I read one of the threads here were
someone had same issues and said they had a freezen problem with the feul pump relay.?? If pump is still in run mode would this prevent injectors to fire.
I have pressure at rail and I have cleaned the iac sensor.This problem has me stumped.What would make pump not shut down becuase of outside temp and prevent truck from starting.This truck runs perfit when it starts at warmer temps.
Old Jan 7, 2006 | 07:53 PM
LxMan1's Avatar
LxMan1
I would suspect either the fuel pump relay or the EEC relay. They are both located under the hood.
Old Jan 7, 2006 | 11:49 PM
stevcher's Avatar
stevcher
cold start problem ????
were are the relays on my 1992 f150 and again if pump doesnt stop on the start up ,does this stop the injectors from firing?
Old Jan 8, 2006 | 12:30 PM
LxMan1's Avatar
LxMan1
Could be if the ECM isn't isn't seeing feedback due to a bad relay. They are ususally under a cover on the drivers side under the hood. The fuelpump relay is green and I believe that the EEC relay is grey.
