its practical. pretty much a drop in, just bolt up. but a solid axle swap is more practical than a ttb setup. ttb sux in my oppinion. check out this site. http://soderblom.net/bronco/tech/
Practical money wise or time? One concern I would have is I think the crossmember under the motor is different between the 2 and 4 wheel drives, but I'm not completely sure. Do you have a donor truck? Would it just be easier to sell the 2 by and buy a 4x4? It's really a matter of choice of how involved you want to get.
if he goes with the ttb setup, its a complete bolt in, just need the driveshafts, t case, and ttb. the sas requires some work, but i think is totally worth it.
If I decide to do this it will still be my DD so I thinl that I would go with TTB as this will not be a truly radical vehicle. Basicaly just thinking outloud at this time.
f250 2wd and 4wd are 2 completly different animals.
Leafsprings for 4wd, coils for 2wd. The 2wd and 4wd place the axle pivot brackets in different places on the crossmember. the front frame horns are different on 2wd and 4wd so you need to cut the bottom of the frame out and weld in shackle brackets. It can be done, but its definatly not a bolt-in.
A F150 is an easy bolt-in conversion.
you can put a f150 TTB under a 2wd f250 if you completly strip the frame to the rails and replace and relocate all the brackets, drill new holes, 150 radius arms a 3/4" longer than 2wd F250 arms. you still have a TTB beams that are thinner than the 250 beams. If you want 8 lugs in the front you need everything from the hubs out including stubshafts from a chevy D44 and that takes alot of work/fabrication (the ford 8 lug stuff is just completly incompatable)
This is what I thought I have a line on a 4x4 for cheap I think that I'll just swap bodies. thanks
he will have to use an F150 ttb, as the 4x4 3/4+ ton stuff is different than the 2wd stuff (which is exactly the same as the F150 stuff)..
