Sponsored by: Real Truck
yet another lift question!
Old Jan 6, 2006 | 09:50 PM
bf250's Avatar
bf250
alright, i have a 2004 f250 6.0, my understanding is a f350 sits about 2 inches higher than a f250. so....if i buy a 4 inch lift, it would be the same as adding 2 inches to a f350? or is there something wierd to it that i missed? seems like a stupid question, i don't want a complicated/radical lift, looking at a 350, 2 inches would be fine for me. i am asking so it means i don't need anything special like a pitman arm or worry about driveshaft angles and such? thank you.
Old Jan 6, 2006 | 10:05 PM
BFR250SD's Avatar
BFR250SD
The back is 2" higher, not the front.
You will want a drop pitman arm, so that the angle between the drag link and the track bar remain the same, otherwise you get binding between suspension and steering components. Plus, the increased angle that the drag link is operating at will increase your turning radius. Like any of the SD's need to make bigger circles.
The actual lifts vary from manufacturer to manufacturer. It also depends if you are lifting with blocks, add-a-leafs, or all springs. The best thing to do is contact the specific manufacturer and see what their measurements actually are.
Most of them are the same kits for the 250's and 350's, the difference is when you specify diesel and get the heavier springs, but the amount of lift is usually the same.
If you don't want anything radical, just do a 3.5" leveling kit and you'd be all set. For a 350, this would sit you nice and should clear 35's.
BFR
Old Jan 6, 2006 | 11:39 PM
biz4two's Avatar
biz4two
BFR
I agree with BFR250SD with the front kit. However, I would like to add that you might want to include the F350 4" rear blocks over the F250 2" blocks. IMO...
Lots of choices...good luck!
biz
Old Jan 7, 2006 | 01:10 AM
BFR250SD's Avatar
BFR250SD
Sorry, misunderstood! I thought he had the 350. Good catch biz.
Absolutely, get the 350 blocks with it. Make sure you get the u-bolts as well.
If not, just get a 2" level and you'll clear 33's real nice.
Here's some food for thought to help you out. Page 2 has a some comparison pics.
https://www.ford-trucks.com/forums/s...ight=Lift+Kits
BFR
Old Jan 7, 2006 | 09:22 AM
pbr man's Avatar
pbr man
BFR
I am looking at a 2.5' leveling kit for my F350, would I have to get a drop pitman arm. I don't want to get into alot of added expenses just to raise the front of the pickup.
Old Jan 7, 2006 | 01:58 PM
bf250's Avatar
bf250
thanks for the replies, i went off of bfr250sd advice awhile back, now just trying to refine everything and come up with a way to do what i want. now its time to look for the lift and the wheel and tire search!
Old Jan 7, 2006 | 07:39 PM
Bruce F250's Avatar
Bruce F250
hey guys Im new to this forum and have similar ??
I figure I'll just continue this thread, rather than start another.
I have a 04 F250 6.0psd. I just ordered BFG 315/75/16 and 16x10 MT wheels.
can I get away with 4" blocks and a leveling kit ? or do I need a complete 4" suspension lift?
thanks in advance
Bruce
Old Jan 7, 2006 | 09:40 PM
bf250's Avatar
bf250
thanks in advance
Bruce
i got this from bfr250sd(hope you don't mind)
"As far as tire sizes. Some guidelines to look at with these trucks are.
Leveling kit works good with 33x12.50's.
4" works good with 35x12.5's, but you have to get wheels with a backspace of 4 1/4 to 4 5/8 or you will have some rubbing issues. Also, this is okay for light off-roading, but if you wheel it hard get the 6" for 35's
6" works good for 36x12.50's or 35x14.50's. Again, the backspacing is crucial with the wider tires.
8" works good up to 38x13.50, but is best on 37's for wheeling."
what i got from this is get the 3 1/2" leveling kit and throw a 4 inch block on the back and 35" will fit fine.
Old Jan 7, 2006 | 10:57 PM
BFR250SD's Avatar
BFR250SD
thanks in advance
Bruce
Welcome to FTE!
Can you do it? Sure! The only problem with that is you would have to piece together some components to acheive the end state.
4" lifts w/ blocks are relatively cheap. I would look at a few of the 4" lifts and compare some prices. You might be surprised by what you get for the price of a whole kit.
For 4" of lift, check out a Superlift setup and you should be all set.
But yes, a front leveling kit w/ some F350 blocks and u-bolts in the back would do you just fine. Just make sue you get a 3.5" leveling kit or you'll still be nose down. 2.5" might rub a little with 315's.
BFR
FordF350Baby
Feb 7, 2009 08:59 PM
jrquinto
Mar 8, 2008 11:06 AM
73strokin
Offroad & 4x4
20
Jan 16, 2007 07:48 PM
LWM97
Jan 6, 2004 02:36 PM
