my dad has a 72 f-250 4x4 with a 360 and 4 speed. one day when he was driving he noticed that the headlgihts were kind of flickering, so he changed the voltage regulator. then the alternator quit charging so he also replaced that, and now we still cant get the alternator to charge. i was wondering if maybe we had a wire that was bad cause with the alternator hooked up you could take a wire tester and the whole outer case of the alternator would be hot, so now we moved one of the wires to a different spot on the alternator and it isnt hot anymore, but we still cant get a charge out of it. we are out of ideas so tomorrow we are going to a junkyard to look for a alternator wire harness for it. do any of you guys have any idea of what could be wrong?
Check the battery connection at the starter solenoid and battery.
Check the negative ground cable at the engine, make sure it is making good clean contact.
Check for proper connections at the Voltage Regulator (VR) and at the back of the Alternator (Alt.). Check for any crack or loose wires.
Check the fusable links from the starter solenoid to the alternator. Will need to peel back the rubber tape to expose the wires. Check the soldered connection where the fusable links are joined.
Check ground from the body to the frame.
Remove alternator and have it rre-tested, It could be a defective alternator and has gone out.
I just went through the exact same thing. The new regulator I bought was bad. I took it back and they tested it and told me it was good. I replaced it anyway and tah dah! For 20 bucks, I would try another regulator. Hope this helps.
Check the fusable link, connections and wires which runs from the starter solenoid (positive side towards battery) to the alternator, you will need to peel back the electrical tape to expose and inspect the fusable links, electrical wires, and the soldered connections.
Then you can peel back the electrical tape to expose the wires from the voltage regulator to the alternator joint connections. Check all connections, wires, and fusable links.
If you decide you do need a fuse link, here are the color codes with wire lengths.
<!-- / message --><!-- no sigs except when logged in -->
we got it fixed turned out it was the wiring. we went to a junkyard and found a 73 with a 360 and pulled the alternator/voltage reg wiring harness and plugged it into dads 72 and now everything works fine except for the flickering lights we cant quite figure that out yet. and now we found a really bad tie rod end when we were greasing the front end so now we have another project for this weekend.
If you just have a headlight prob, I would check that circuit. maybe replace the switch, they are cheap and easy to pull. Could be a bad ground, bad wire etc. Do they flicker only when driving, or all of the time? If you change reg, make sure it is bolted on before you hook wires to it.
Baitmaster is right. Check the ground for the headlights. Also check the ground from the body to the battery, many are missing or not hooked up. good luck hunting. DAHMER
