Tools for the beginner
Old Jan 6, 2006 | 07:05 PM
helifixer's Avatar
helifixer
Talking Tools for the beginner
Tools for the beginner...........
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly-stained heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar calluses from fingers in about the time it takes you to say, "Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to further round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over tightened 50 years ago by someone at Ford, and neatly rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also the next tool that you will need.
EXPLETIVE: A balm, also referred to as mechanic's lube, usually applied verbally in hindsight, which somehow eases those pains and indignities following our every deficiency in foresight.
Old Jan 6, 2006 | 08:19 PM
preppypyro's Avatar
preppypyro
Damnit tool haha priceless
Old Jan 6, 2006 | 09:39 PM
chris12's Avatar
chris12
classic especially the Dammit tool
Old Jan 6, 2006 | 10:09 PM
TigerDan's Avatar
TigerDan
I've had a lot of those over the years...durn near every tool I've ever owned has done that duty at some point or another.
DON'T use your torch handle for a dammit tool though...it's not sturdy enough and gets expensive really quick!
Old Jan 7, 2006 | 09:16 AM
Beast12's Avatar
Beast12
SOOOOOO true!
-Matt
Old Jan 7, 2006 | 10:23 AM
ckal704's Avatar
ckal704
I was supervising Saturday Detention (ala "The Breakfst Club") as I read that.
The kids thought I was having a siezure because because I was shaking from not being able to laugh out loud!
Old Jan 7, 2006 | 10:53 AM
oojbearoo's Avatar
oojbearoo
i also at one time owned dammit car parts too
Old Jan 7, 2006 | 07:55 PM
hotroddually's Avatar
hotroddually
you can never have to many tools.especially big hammers for fixing non ford type vehicles
Old Jan 7, 2006 | 08:31 PM
wolfman01's Avatar
wolfman01
That whole thing is classic!!!! I had a horrible time not laughing out loud as I'm at work. THANK YOU Helifixer for making my evening.
Old Jan 8, 2006 | 01:44 AM
Oval_obsessed's Avatar
Oval_obsessed
I can relate to everyone of those. Especially the dammit tool.
Old Jan 8, 2006 | 02:00 AM
Maxium4x4's Avatar
Maxium4x4
Oh how that hits home......
aerocolorado
16
Apr 13, 2009 07:21 PM
e1p1
Apr 21, 2008 04:40 PM
77redf250
13
Mar 15, 2004 06:25 AM
