lift pump, fuel pump ?
Old Jan 6, 2006 | 05:32 PM
shendoa's Avatar
shendoa
how can you tell if you have the original lift pump , and that it has never been changed, any ideas? is their some special mark or tag ?
Old Jan 6, 2006 | 06:08 PM
1997F-350's Avatar
1997F-350
you got me man...
i guess look and see if the amount of crud on it matches the valley and if it looks cleaner where it meets the valley on the pump then it may have been changed???
i dont know....
whats wrong?
Old Jan 6, 2006 | 06:14 PM
shendoa's Avatar
shendoa
Tproblem my engine is clean, everything is clean, that what i get for keeping things clean.
Old Jan 6, 2006 | 06:17 PM
shendoa's Avatar
shendoa
thaught thair might be some tag on original or something Thanks 97F350
Old Jan 6, 2006 | 06:58 PM
1997F-350's Avatar
1997F-350
i am not sure... i dont even want to look at that thing(it might start leaking if i do) lol
thats all i need right now.
Old Jan 6, 2006 | 08:44 PM
Kenworth's Avatar
Kenworth
My lift pump is leaking I'am going to try keep running it that way for a little bit. I got the price for a new one which is 300 dollars CND I have to phone around to see how much difference in price. I doubt there will be
Usually the Ford dealer doesn't want anything to do with older trucks I doubt they would even have that in stock.
I have to go see the new mechanic that works in one of the shops here he drives a OBS PSD so he probably knows how to work on them. I'am not going to tempt it myself.
Old Jan 7, 2006 | 04:32 AM
1997F-350's Avatar
1997F-350
ebay.............you can get one cheap.
Old Jan 9, 2006 | 06:32 AM
MikeFromShiloh's Avatar
MikeFromShiloh
I changed my lift pump, bought it from NAPA for around 135. Been on a yr or so, everything doing good. Have good pressure and no leaks, what more can you ask for.
The OEM fuel line is blue. I would bet if the fuel lines are blue it has not been changed before.
good luck
Old Jan 9, 2006 | 08:58 AM
shendoa's Avatar
shendoa
You have a point, blue lines, yes thanks,
