Kwik Mod
Old Jan 5, 2006 | 08:39 PM
99F-250lova's Avatar
99F-250lova
Question Kwik Mod
So I put the kwik mod in my truck. That is great and all. I am not sure if I have to put my O2 sensor back in or not. Can anybody tell me if I need to find a way to put it in or can I just let it hang?
Old Jan 5, 2006 | 08:41 PM
guzzle92's Avatar
guzzle92
Just zip tie it to anything that is close to the filter.
Old Jan 5, 2006 | 08:43 PM
SpringerPop's Avatar
SpringerPop
Your Powerstroke hasn't got an O2 sensor.
If you mean the little Inlet Air Temperature sensor, just zip-tie it to a convenient brake line or bracket to keep it from flopping around and getting broken.
Pop
Old Jan 5, 2006 | 08:59 PM
99F-250lova
Thank you springer! I guess I have to feel stupid sometimes.
Old Jan 5, 2006 | 09:20 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
no stupid questions around here.
everyone has to learn at one time or another. everyone once felt "as stupid" as you do.
Old Jan 5, 2006 | 09:41 PM
SpringerPop
Stroker,
Y'a know, for a youngster, you sure have a lion's share of common sense, not to mention you learn complex issues pretty quickly, and are able to teach them in simple language to others.
You are a real credit to your folks. They brought you up right.
I'm glad you're around here.
Pop
Old f@rt.
Old Jan 6, 2006 | 04:55 PM
maevans's Avatar
maevans
Originally Posted by SpringerPop
Stroker,
Pop
Old f@rt.
You just said what i was thinking !!
Old Jan 6, 2006 | 05:55 PM
guzzle92's Avatar
guzzle92
Your Powerstroke hasn't got an O2 sensor............
Yea, but I knew what he was talking about
Old Jan 6, 2006 | 06:24 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
I put the Inlet Air Temperature sensor in one of the holes left behind after pulling the stock box out. If you lift your Kwikfilter up and look where it rests on the plastic, there are two holes. I drilled a notch in one of them and inserted the sensor from the bottom, once thru give it a quarter twist and its there. The sensor is right under the filter. Also if you don't want to disconnect the filterminder,pull the rubber gromet off the filterminder and put it on a hole that is already there on the fender then stick the filterminder in.
Old Jan 6, 2006 | 06:28 PM
maevans's Avatar
maevans
Smile
For that guzzle92, You get a gold star L O L .
Old Jan 6, 2006 | 06:40 PM
guzzle92's Avatar
guzzle92
Great, that's my first one!
