Tire Pressure
Old Jan 5, 2006 | 05:06 PM
bassproguy07's Avatar
bassproguy07
Tire Pressure
Anyone know how much the tire pressure should be on an 83 f 250?? the door says 80 n the rear and 51 in the front are those numbers rght???
Old Jan 5, 2006 | 05:09 PM
DeepRoots's Avatar
DeepRoots
80 all around for me.... its easier to remember
Old Jan 5, 2006 | 05:11 PM
seventyseven250's Avatar
seventyseven250
Go with the numbers listed on the truck as long as you don't exceed the max pressure of the tires.
Old Jan 5, 2006 | 05:16 PM
bassproguy07
Max Pressure for the tires is 80 PSI, i put 80 in the rear and 51 in the front
Old Jan 5, 2006 | 05:35 PM
patagonia's Avatar
patagonia
Red face
I used 35-38 PSI without load in front and rear. With load I used 45 - 55 in the rear tires only.
Old Jan 5, 2006 | 06:14 PM
BikePilot's Avatar
BikePilot
I use 80 all around
Old Jan 5, 2006 | 09:10 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Read on the tire sidewall.
I always run mine at the inflation for max payload which is listed on the sidewall.
Better fuel mileage, the ride is not that much different.
