PSD burn outs video
Old Jan 7, 2006 | 06:07 AM
maevans's Avatar
maevans
[QUOTE=1997F-350]here this page has about 100 VIDEOS.
http://www.diesel-central.com/Video/Video.htm[/QUOTE]
Thanks 1997F-350
This will take me the next 2 hours to watch, O'l well i'ts to cold to wash the trucks here.
Old Jan 7, 2006 | 09:24 AM
kilapapipa's Avatar
kilapapipa
Thanks to all for the video links, I am having a ball watching these.
Old Jan 7, 2006 | 12:42 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
that black crew cab that ran the 11.42 supposedly had a 12v worked cummins in it.
Old Jan 7, 2006 | 02:43 PM
1997F-350's Avatar
1997F-350
it does that maddog's truck...its dark green like mine....
Old Jan 7, 2006 | 09:29 PM
kennedyford's Avatar
kennedyford
I cant get mine to break loose except on marbles or water.
Old Jan 8, 2006 | 02:46 AM
twags6's Avatar
twags6
If you drive an auto, hold the brake and give it some throttle to get the turbo spooled up and then let the brake go and mash it. I tried it tonight on the way home from work and wow, what a difference.
Old Jan 8, 2006 | 06:09 AM
maevans's Avatar
maevans
twags6
When can we except to see your video, Sounds like your getting some practice.
Old Jan 8, 2006 | 10:09 PM
cangim's Avatar
cangim
Okay, so I have a problem that every time that it rains, the rear tires just don't seem to grip to road, infact the rotate rather fiercely. Almost to the point of doing doughnuts in the middle of a two lane intersection. Of which was kinda scary the first time, but after that, on to the COOKIES!!! Did I mention that happens in the snow as well?
Old Jan 9, 2006 | 11:30 AM
doc526's Avatar
doc526
Pretty Cool!! Ford Performance Specialists is about 15 minutes from my house.
Old Jan 9, 2006 | 04:55 PM
Brian0445's Avatar
Brian0445
Smile
cool video's
Old Jan 9, 2006 | 09:54 PM
BadFord99's Avatar
BadFord99
Sweet video man. I play around every once in awhile, (tires cost to much to replace too often). I just love the sound of my turbo screamin and the smell of burning rubber, and the looks on peoples faces when they see raw power in action.
Old Jan 13, 2006 | 10:21 PM
kilapapipa's Avatar
kilapapipa
Watch it again and crank up the volume. Tell me that doesn't sound like a PSD when it is idling before the start. I am not saying you are wrong but give it a listen.
Old Jan 14, 2006 | 02:35 PM
  #28
empiretc's Avatar
empiretc
That is a twin turbo cummins in that truck.. That video has been going around for years. I will try and track down its source again, cuz i had it hosted on a website for a long time..
Old Jan 14, 2006 | 03:01 PM
  #29
PowerstrokeJunkie
how many pounds of pressure do you have in the rear tires? the tires i had before were rated at 80psi MAX, and i ran 55psi rear and 65psi front (fronts tend to bulge alot), and it helped with traction, and smoothed the ride some.
Old Jan 14, 2006 | 03:42 PM
  #30
cangim's Avatar
cangim
I run low in comparison to most, empty I run 44 up front and 36 in back, that is where the tire rides flat on the road... The loss of traction mainly comes from the heavy right foot. One of those adolescent things I guess.
chewedtoothpick
Mar 20, 2013 09:19 AM
brd7666
20
Jan 9, 2011 01:12 PM
big poppa
18
Jun 2, 2009 05:56 PM
mueckster
Feb 26, 2009 09:00 PM
strangmk
Mar 20, 2004 10:59 PM
