Thanks for the input you two, If the box doesnt fix it, which I dont think it will, Im gonna take care of making sure we have a good ground on Saturday, if that doesnt fix it, Ill start looking at the distributor, which will entail pulling it out and throwing it in the trash can
Do you have the correct resitance in your coil? That was my problem once, it ran 200percent better after I fixed it. And my distributor lobes were toast. Points need X resistance and electronic needs Y resistance.
One grounding point that is often overlooked is at the holddown screw inside the distributor that secures the stator assembly, it is the ground for the stator.
Another trouble spot(s) are the multipin plugs in the ignition system, There are three of them, make sure they are clean and tight.
kspilkinton, as far as I know there are coils that have different internal resistances. Sometimes you have to use an external resistor to have your distributor system work correctly. Am I wrong or insane?
No, your right, I have the correct coil. Several of them in fact, it makes no difference in the problem.
Matt, you're right on, it's just you started going into impedance (resistances with different phase angles)... a little more than technical. Was just razzing you...
In detail - off the cuff- correct me if you see a flaw in my reasoning:
Coils are inductors first, resistors second. This is a DC system, but the coil builds up a field and discharges it, so in fact it is a weird AC. You'll have the properties of both AC and DC in the ignition system after the Duraspark box. This is partially why we use ballast resistors in some systems. The ballast resistor is really a filter/capacitor... in the end we are trying to make a power factor as close to one - or make the inductor/coil impedence match the filtering circuit/ballast resistors impedence. This should be taken care of by the electronics of the duraspark. However, if the impedence cannot be matched due to the limitations of the electronics, you will experience problems. These probelms should be evident all the time, and in Kevin's case, they are not.
This is why I'm leaning towards an electrical problem on the input side of the ignition module. The input voltages being slightly off when cold, then right on when the truck is warm indicates a gound that is related to engine temperature.
Thanks man. I was just giving ideas. I'm not working on this truck and it wasn't mentioned yet. And thanks for the friendly jab. I thought you thought I was talking about someting else. I know it's all ball bearings these days, even in mufflers!
