Group Tech Article Ready for Viewing
"Just a small comment on the Mopar columns as a general FYI (for any and all out there). The Mopar and the GM tilt columns (which basically all the aftermarket columns are based on) are the same. I think they were manufactrued by Saginaw."
I'd mention something vaguely like this..
Steering column from RWD Chrysler products 1976-89. Key on column. Correct spline on the rag joint if you are using a Mopar based IFS.
Wouldn;t have to mention it, but just as an aside, this column is a better fit than many of the other columns mentioned in the article as it tends to be shorter. Unfortunately it comes with a stupid looking ignition key onboard.
...and about the dumb key... anyone found a viable way to graft a Mercury or Ford Key end to the Chryco shaft?GW
Thanks. It's tempting to try and use the Mopar column because it is perfect in length for a 48-52 and it's free if you buy a donor for your front suspension but the lack of wiring kits for it and other shortcomings make it a poor choice and I wanted others to avoid making the same mistake I did by using it.
Vern
Vern
The Toyota steering box adaptation is a separate, stand-alone article. It is actually going to George tonight.
Johnsf,
Sorry, but other than minor edits/corrections I don’t plan any new additions/topics for this article. I know I have put at least 30 hours into it already(possibly more) and George and Himmelberg have put some time into it as well. I’m not prepared to put much more of my time into it (need my time to make progress on my dash install – real work, not an article) and this article was intended to address the major FAQs not already covered by the IFS and rear end articles, but not every possible thing….
Lastly, when I’m writing about something I don’t have much/any first hand experience with, I have to rely on what others have done and written about. If the material isn’t there or I haven’t done it, then I can’t write it up.
‘fenders,
I appreciate all these wee updates from you. Just wish you could keep focussed long enough to put them all out here at one time. I know AADD isn’t easy to control, but we’re trying to go to press here….
Later,
in defense of my cuz.... he politely danced around this in his post.. This FAQ is not a collection of all information available on all ford related subjects... it was simply meant to be a list of Frequently Asked Questions that the newbies and those of us with CRS keep asking.
some of the subjects submitted would make wonderful technical articles and would take several pages and many photos to be useful.
We need to consider this FAQ a cheat sheet for the main subjects... not the term paper you didn't write till the last minute.
Kicking my soapbox back under my truck....
john
BTW... if I haven't said it before Cuz, George and Peter.... outstanding work and thanks for all the time you guys invested in this... now could you just add one tinsy little thing... How to build the cheapest hottest 460 in the world... with all the possible permutations please ???
(Didn't think I'd ever be accused of being too subtle
)Yes, this FAQ thing should be thought of a "What to". It was never intended to be a "How to".
This article is really just a careful summary of about 1,100 threads from which we gleaned the cream and summarized it. We agreed it would help us (regulars and newbies alike) trying to find out what works and what doesn't or what others have done or haven't. It should cut down on lengthy searches for a lot of people. Now people can read the FAQs and then do searches or ask questions on the possibilites they're most interested in.
It would be good to see more tech articles on some of these subjects, although John has already done several (column, gas tank & others) and some others simply aren't that difficult.
I would still love to see someone do a tech article on installing bear claws (with lots of pics plse!!!).
BTW -
I would think that the final version will end up be included via a link in George's references thread up top. In the first revision we are adding links within this tech article to other links that are already in George's thread. That may sound like an endless loop, but there's a reason for it;
We tend to think of this forum as our own private little world, where only we can see in. If someone goggle's the right phrase, they pull up our tech articles and even our threads..... The looped links will help those folks get to know about our resources here..... (Aren't we thoughtful?)
This is not meant to stifle discussion/suggestions/criticism, just to clarify our mission. So continue....
Thanks,
I went back and re-read the document to find that little error I found when reading the first time but forgot where it was.
Radiator Section - line 3 reads:
Although you can take some measurements and pull something at a wrecking yard, but you may be getting a leaky radiator with little or no guaranty on it.?
I suspect that you intended to omit either the word "Although or the word "but" to make it read as you intended.
For something as invovled as this, I think you did a wonderful job. Thank you.
here's the beginning.... haven't put the post in the doors yet but the latches are complete
cuz
Thanks,
John F.
" I appreciate all these wee updates from you. Just wish you could keep focussed long enough to put them all out here at one time. I know AADD isn’t easy to control, but we’re trying to go to press here…."
Sorry about that RMF. Guess I'm not here enough to know what you're doing. I won't distract you anymore.
Plse change it to;
”You can take some measurements and pull something at a wrecking yard, but you may be getting a leaky radiator with little or no guaranty on it. “
(Thanks Texan for catching that.)
Cuzin John,
Bear Claws. Can’t access it from work but assuming it’s progressing at your normal standards, THANKS!
‘fenders,
Ah, lighten up buddy. Just busting your chops. Are the constant bullets whizzing by your head effecting your sense of humour?
Later,
It's good to see your comments and counsel. Jag
