Throttle cable mounting
Old Oct 29, 2001 | 01:11 PM
DanieC's Avatar
DanieC
Hi out there. I have a F100 with a 351C that I built into it, just one little hassle I don't know what the bracket/mounting looks like where you fit the throttle cable just before the carb. Is there any fordnatic out there that could perhaps email my a pic of said bracket? Thanks Danie Claassens South Africa
claassdj@intekom.co.za
Old Oct 29, 2001 | 01:27 PM
dfisher1's Avatar
dfisher1
DanieC
There is no cable. There is a linkage. The throttle pedal has a rod which rotates from the firewall penetration up to the top of the motor. The top of the rod has a hole in it which a secondary rod pivots in. this secondary rod is threaded and can be shortened or lengthen to fit which ever carb you have. The carb must have a ford throttle ball. The secondary pivot rod has a socket on the end of it and this socket snaps onto the throttle ball. A separate piece of linkage on the carb will attach to the kickdown linkage for the transmission kickdown lever. It's that simple, unless yours is missing. Then it's not that simple.
Good Luck, Have Fun,
KingFisher
Old Oct 29, 2001 | 02:54 PM
DanieC's Avatar
DanieC
Yup it's not that simple.It seems all the F100's and F250's manufactured here (South Africa) had a throttle cable and not the American type linkage.
What now. I would appreciate any suggestions.
Old Oct 29, 2001 | 03:30 PM
BigBrownTruck's Avatar
BigBrownTruck
I recently was involved in helping a friend swap a 6 out his truck and replacing w/ a V8. The six had a much different cable linkage than was right for a V8. He had a Carter AFB carburtor. We purchased a little aftermarket bracket that bolted to the studs that the carb is bolted down on. It was made by Russell. My 79 F150 that has a 302 in it has a cable between the throttle pedal shaft at the firewall. It just pulls backward against the two throttle return springs. There is no bracketry, it just is a straight piece of wire w/ a swivel "pop-on elbow" type connector on the carb and a simple piece which I don't know the technical name of, but it's just a little block of something that sits in the throttle pedal flapper shaft (another technical term eh?) Perhaps you could persuade someone here in the states that's parting out their truck to send you their pedal and straight rod linkage if you'd rather have the solid rod type.
BBT
Old Oct 29, 2001 | 03:37 PM
StockMan's Avatar
StockMan
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
What year truck are we talking about here? My '66 F250 I6 has a cable whereas the '67 and up models had a linkage. I could never figure that one. Perhaps the overseas trucks are similar to the older series in this regard. A picture would help.
[/FONT]
https://www.ford-trucks.com/dcforum/User_files/StockMan/flag.gif
[FONT COLOR="#ff0000" SIZE="+2" FACE="Signature"]Stock Man[/FONT]
[FONT COLOR="#0000ff" SIZE="3" FACE="arial"]
[LINK:www.ford-trucks.net/users/stockman|Stockman's Club FTE Site]
[LINK:www.67fordtruck.com|1967 F-Series Registry ( www.67fordtruck.com )]
Old Oct 29, 2001 | 03:51 PM
mike460's Avatar
mike460
hey, maybe you should try a lokar universal throttle cable. they seem to be excellent for solving problems like this one. i think the website is www.lokar.com and the part number would be tc-1000u
good luck
mike
Old Oct 29, 2001 | 06:17 PM
Mil1ion's Avatar
Mil1ion
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bddf1790d212b0b.gif
Happy Hallo'ween
Exactly what year is that engine and truck ?
Cable throttles have a bracket that bolts to the intake,this bracket has a square hole in it for the cable end to Snap into .
I'll see what i can do from this end as I have a bunch of brackets that I just sorted out in the garage.
Dennis
78 F-150 429CJ 465,000 KM.(Original Owner)
68 Mustang 289 Sunlit Gold 80,000 Miles(second Owner)
64 1/2,260 Pre-World's Fair Mustang #8092
64 Fairlane 500 S/C,waiting for a 390 4-Spd
If The Girls Don't Find You Handsome,
They Should At Least Find You Handy!
Old Oct 29, 2001 | 11:34 PM
DanieC's Avatar
DanieC
Thank you for all the responses. The truck is a 1974 model which looks exactly like the American F100 only it's right hand drive and is basic ie no p/w steering, no a/c, just your bare to the bones truck. The engine I'm not sure about I never checked the casting number.
Old Oct 29, 2001 | 11:57 PM
XeontisTeknobot's Avatar
XeontisTeknobot
