Sponsored by: Kumho
drop question
Old Jan 4, 2006 | 05:10 PM
bigjace8's Avatar
bigjace8
drop question
does any know if it is possible to lower a 00 expo 4wd without major surgury? i would imagine the front isnt to hard because it has torsion bars but the rear is where im lost.
Old Jan 4, 2006 | 11:02 PM
thesprocket26's Avatar
thesprocket26
1st, why? 2nd, IRS or leafs? 3rd, smaller tires.
Old Jan 6, 2006 | 07:10 PM
bigjace8's Avatar
bigjace8
why not? leafs, i would rather not change the over all diameter of tires i would run bigger wheels smaller tires. if i would only run smaller tires tires that defeatthe purpose of lowering the truck
Old Jan 6, 2006 | 07:17 PM
thesprocket26
Usually you lift a 4wd. Could you trade it for a 2wd? The rear would be easy to lower with custom springs, but the front would be a nightmare. If you just untwist the torsion bars it will screw up your alignment. I don't know if there is enough adjustment to straighten it back out.
