does leaky radiator cause other problems?
Old Jan 4, 2006 | 02:02 PM
Truckmano5's Avatar
Truckmano5
could a leaky radiator cause my heater core to go bad?
Old Jan 4, 2006 | 07:45 PM
Ultramagdan's Avatar
Ultramagdan
No, I wouldn't expect anything from that unless whatever caused the rad to leak could also affect the heater core.
Old Jan 4, 2006 | 07:57 PM
The SnoMan's Avatar
The SnoMan
Well kinda in that if it is leaking from corrosion and age, the heater core may not be far behind.
Old Jan 5, 2006 | 12:46 PM
rebocardo's Avatar
rebocardo
Whatever caused (maybe bad ground or bad antifreeze) the radiator to go bad can cause the heater core to go bad. Though what usually kills the heater core is rust and scale getting lodged in it, depending on design. In the worse cases, what happens is a sludge of sorts builds up inside the tubes and eventually clogs it.
Old Jan 6, 2006 | 11:35 PM
Truckmano5's Avatar
Truckmano5
is there a way you can properly ground the radiator to stop electrolysis?
OLDBLUEF250
Jun 20, 2016 09:01 AM
Wildpat01
Feb 27, 2016 08:24 PM
93-331-29PSI
6.7L Power Stroke Diesel
Feb 18, 2016 03:42 PM
Redagain
Aug 29, 2015 10:58 PM
Steve
Dec 20, 2014 05:57 PM
