1978 - 1996 Big Bronco
whistling noise
Old Jan 4, 2006 | 01:41 PM
poffutt's Avatar
poffutt
Talking whistling noise
89 EFI EB Bronco w/351 Stock engine
I have a whistling noise in my engine. It is not in the drive train because it does is at idle and progresses with the exceleration. It has a brand new
belt
alternator
cluch fan
power steering pump
and the water pump is one year old (remanufactured)
some times it goes away but not very often.
I have noticed that my oil pressure gauge is runing lower than it has for the past year. (I don't know if oil pumps can whistle)
Can anybody help. I have a feeling it is the water pump...don't know.
Thanks
Old Jan 4, 2006 | 02:15 PM
7fords's Avatar
7fords
did you check for vacumn leaks
Old Jan 4, 2006 | 02:29 PM
poffutt's Avatar
poffutt
No, actualy I never thought of that cause my engine is running so fine. Do you think I could have a vacumm leak with no change in the performance?
If so, what is the best way to check them.
Old Jan 4, 2006 | 10:48 PM
djjoshuad's Avatar
djjoshuad
it does sound like a vacuum leak. Look around for any hoses that have one end not attached to anything else. It might help to have the engine running (and whistling) when you are looking for the leak. One common place for this to happen is the PCV valve. If that thing comes loose, the whistle is pretty loud.
Old Jan 5, 2006 | 10:21 AM
poffutt's Avatar
poffutt
I went home and removed my belt to ditermin that it was in the belt and accesories system. I removed the belt and started the engin. There was no more whistling...that is what I expected. So I put my belt back on and now their is no whistling at all. So I don't know what happen but I am happy. Thanks for you alls comments.
