squeeling break
Old Oct 28, 2001 | 01:43 PM
fordblue_ca's Avatar
fordblue_ca
squeeling break
I have a 79 f-250 2wd truck and there is a squeeling sound coming from one of the front breaks when driving. But when you apply the breaks it stops. Is there something that I can do about this. The breaks are fairly new.
Thanks,
Joe
Old Oct 28, 2001 | 02:00 PM
Mil1ion's Avatar
Mil1ion
squeeling break
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bdc55325f5a06d2.gif
Lots of things cause BRAKES to squeal.
Did you do them yourself?
If not, take it back to the shop that did the work and get them to fix it.
Sometimes dirt gets lodged in the pad area.
Maybe try some Brake cleaner near where the rotor meets the pads.
Sometimes it could be the type of rotor vs pads material being metallic/semi-metallic/organic
If I get a squeal , I put a good dust mask on and blow the area out with the air hose,that usually works.
*Warning don't ever do this without a breathing protection device.
Dennis
78 F-150 429CJ 465,000 KM.(Original Owner)
68 Mustang 289 Sunlit Gold 80,000 Miles(second Owner)
64 1/2,260 Pre-World's Fair Mustang #8092
64 Fairlane 500 S/C,waiting for a 390 4-Spd
If The Girls Don't Find You Handsome,
They Should At Least Find You Handy!
Old Oct 28, 2001 | 07:38 PM
tetraruby's Avatar
tetraruby
squeeling break
Some pads are designed to squeal when it's close to time for a replacement. When was the last time you had your pads changed?
Old Oct 29, 2001 | 09:52 AM
tamarackstyle's Avatar
tamarackstyle
squeeling break
ive tried running all kinds of pads on my 77. The only kind I can seem to use without getting squel is organics.
Old Oct 29, 2001 | 09:59 AM
beartracks's Avatar
beartracks
squeeling break
Did you or your mechanic use the anti squeal goop? I think it's silicone, you put it on the back of the pads to dampen vibaration.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Oct 30, 2001 | 12:51 AM
fordblue_ca
squeeling break
I think you read my question wrong, they dont squeel when you apply them, it squeels when you drive all the time! drives me nuts! . There must be something that rubs that make that sound, sometime's I apply the breaks just to make it stop.
The break pads rotors and drums are all new.
Thanks
Joe
1977 Ford F-100
280,000 miles
Old Oct 30, 2001 | 09:21 AM
tamarackstyle
squeeling break
j-
Mine did the exact same thing with new rotors as well, and I too would tap the brakes to make them stop squeling. I replaced the semi mettalic pads with organic ones and it went away. If I were to take a guess as to why the squeek it would be the age of my calipers and them MABEY not retracting enough, keeping the pads in contact with the rotor ever so slightly. With the organics no metal in the pads so no squeek.
Old Oct 30, 2001 | 04:06 PM
dfisher1's Avatar
dfisher1
squeeling break
Fordblue,
Your using semi-metallic brake pads. They are too hard and they squeal/squeak/chirp/etc. There is the possibility that the wear indicators are bent and touching the rotor prematurely and that can drive you crazy. Organic pads are softer and much quieter, of course they don't last. When you check your pads, glue them down to the caliper piston. Get carried away with this gobblity goop that they put on'em. If you live up north you'll have to place the blue gue on the back of the brake pad and cook'em in the oven to get it to harden. It seems a little extreme but I've had customers that wouldn't settle for less.
Good Luck, Have Fun,
KingFisher
Old Oct 31, 2001 | 01:09 PM
beartracks's Avatar
beartracks
squeeling break
I think the anti squeal stuff works mostly when the shoes are chattering. Also I have seen the warning tang on some shoes misadjusted out of the box. And then some pads are just hard as heck.
1977 Ford F-100
280,000 miles
Old Oct 31, 2001 | 03:20 PM
beartracks's Avatar
beartracks
squeeling break
chadjeppig
20
Apr 1, 2014 11:42 PM
rdeanw
1997 - 2003 F150
Aug 30, 2010 10:18 PM
GRokDevine
Jul 18, 2009 11:40 PM
jkattz
20
Mar 6, 2005 11:30 AM
Wakeboarder141
1978 - 1996 Big Bronco
26
Jan 9, 2004 08:13 AM
