cackle?
Old Jan 5, 2006 | 10:56 PM
  #31
Kwikkordead's Avatar
Kwikkordead
That would be an easier way of doing it. The reason that I chose to feed both heads from the rear is that the engine is slightly tilted toward the rear of the truck. Air always rises and I wanted to feed the heads at the low point and allow all air bubbles to rise to the top and be purged.
Old Jan 6, 2006 | 08:33 AM
  #32
kilapapipa's Avatar
kilapapipa
Originally Posted by cookie88
It's an ITP system. It did get rid of my idle knock most of the time....still hear it occasionally when it's really cold. I also have a couple of injectors that are getting clacky all the time now, but I hope to remedy that soon.
Also...the injectors are a little louder at the higher pressures, but they seem to run better cranked up.
Cookie, so even though I have done all the fuel mods, and I still have some cackle, are you saying that an injector could be bad. I have wondered if replacing #8 might help after 95000mi. of cackle. ????
Old Jan 7, 2006 | 09:03 AM
  #33
99f250's Avatar
99f250
i'd like to know this also.mine is starting to do it on both sides now.what would be the culprit on passenger side of motor?
Old Jan 7, 2006 | 09:10 AM
  #34
Kwikkordead
Air in the fuel, it gets into the right side head just as easily as the left. Just the left head also has to timing order issues that tend to make #8 starve for fuel as well and so it's worse on the left than the right.
Old Jan 7, 2006 | 09:15 AM
  #35
99f250's Avatar
99f250
is there an 'easy' fix?
Old Jan 7, 2006 | 09:23 AM
  #36
Kwikkordead
Not really.
Old Jan 7, 2006 | 09:25 AM
  #37
99f250's Avatar
99f250
could it be a 'warranty' issue?
Old Jan 7, 2006 | 09:36 AM
  #38
Kwikkordead
It would take a huge fight at the dealer. For the $100-200.00 and one day's work to fix it permanantly, it's not worth it to me.
Plus our truck are off warrenty anyway. They wouldn't do a thing for us.
Old Jan 7, 2006 | 10:54 AM
  #39
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
If you had an air intrusion problem for 95,000 miles it's likely that more than one injector has suffered some damage.
Originally Posted by hllon4whls
As shown by their diagram, why cant one simply connect the two heads at the unused ports to eliminate fuel starvation to the end injectors?
Are you talking about installing a balance tube between the heads, similar to what the high pressure oil crossover line does? It seems like that would provide the air in the rails someplace to go....maybe a little check valve teed into the return line to let the air clear the line at a preset pressure?
The ITP system I use is very similar to the TT diagram, actually, everyone's system is similar to that diagram. The ITP system feeds the heads from the stock locations with upgraded feed lines, then goes through check valves installed in the head outlets to the regulator, and from there to the return line.
Old Jan 7, 2006 | 12:39 PM
  #40
PSNut's Avatar
PSNut
6.0L vs. 7.3L cackle
I just listened to a 6.0 idling in the parkling lot near me and i can't tell much difference in sound.
Old Jan 7, 2006 | 07:49 PM
  #41
kilapapipa's Avatar
kilapapipa
Thanks, Cookie.
Realslowww
Apr 26, 2015 09:32 AM
Mark3682
Jan 27, 2004 01:25 PM
c_nate
Nov 17, 2002 08:52 AM
nobody
Dec 12, 2000 05:21 PM
Captain Roy
1997 - 2003 F150
Dec 21, 1999 11:18 PM
