Sponsored by: Auxito
Vibration when turning
Old Jan 9, 2006 | 09:19 PM
countryboy69's Avatar
countryboy69
replacing the rear end clutches will do nothing for you vibration from a stand still acceleration while going straight, unless one tire is starting to slip, the rear end vib on turns is usually from clutches, vibration while straight line accelerating may be from u-joints,or a binding slip yoke. u- joints usually cause a vib at highway speed,
Old Jan 10, 2006 | 04:50 AM
mat-helm's Avatar
mat-helm
Bad U-joint?
Old Feb 4, 2006 | 12:48 PM
stephen.osborne1's Avatar
stephen.osborne1
hey guys... I drained my diff. and added some new lube with the friction modifier... It isn't "slipping" as much, but still does a little when turning real tight from a stop, especially on an incline. So I'm guessing my clutches are toast... can the limited slip be replace without messing around with the ring and pinion? can a locker just be put in it's place? also, I've noticed a slight "clunk" now when taking off sometimes, like lash. Does that mean I should replace the gears? are there any TSB's or anything of the sort on this subject. Also, If I have to replace stuff, and want to use aftermarket, what should I get?
Old Feb 5, 2006 | 12:57 PM
usmcpao's Avatar
usmcpao
Same Issue
My 2001 Ford F150 Screw has been doing the same thing, much vibration while turning at slow speeds, and it gets worse on an incline (turning right is worse than left). My rear-axle was replaced at about 40K (90K now). Someone earlier mentioned an LS additive? Can you post some more details?
Old Feb 6, 2006 | 06:28 AM
78 short's Avatar
78 short
USMCPAO use ls additive and go do fiqure eights in a big parking lot ...Slow speed and tight as you can for about five minutes....a couple of minutes each way...That will get the ls additive into the clutch pack otherwise it takes a long time to get in there. Your vib gets worse under inclines because there is more torque applied to the diff which tighten's up the clutch pac. I bet you don't feel any vib coasting around corners...or very little. Just fixed the same problem.... Igf you ever get stuck or burn out and one tire lites up by breaking the clutches loose. Then You will probably develope the same thing because you dry out the clutches and it takes a few corners ....alot of corners both directions to get it all lubed up again in there. U-joints that start to get dry and seizing up are the ones responsible for that dreaded clunk under acceleration...just fixed that too. One u-joint was dam near completely seized.
Old Feb 6, 2006 | 07:12 AM
projectSHO89's Avatar
projectSHO89
Parts dept at a Ford store or at almost any decent auto parts store. About $6 for a 4 oz bottle.
Add it to the diff, then do the figure eights as suggested. It's easiest to add through the ABS sensor hole on top since it's a small bottle.
Steve
Old Feb 16, 2006 | 12:14 PM
Dugas's Avatar
Dugas
I had a similar problem on my 2WD 98 F150. Tight turns from dead stop made an awful noise in the rear. There was a thread on this about a year ago. I tried the additives with no luck. Ended up being a combination of worn rear tires and BAD shocks. Since I replaced both, I have not had the problem.
Old Feb 16, 2006 | 01:39 PM
stephen.osborne1
I've got an auburn gear limited slip on the way, and for good measure, new ring and pinion.
Old Feb 23, 2006 | 10:48 PM
78 short's Avatar
78 short
did you say tires and shocks helps a bad vib/noise in the rear end?Wow Thats a head scratcher.Sounds to me like a good upsell job with a free additive thrown in to get rid of your initial problem....
Old Feb 24, 2006 | 08:31 AM
Dugas's Avatar
Dugas
My best guess is that on tight turns when the differential is kicking in one of the tires would alternately start to slip (poor tread) and then grab. As it did this it set up a slight hopping of the wheel which would not get damped out (bad shock). This made the differential chatter as it tried to accomodate this vibrating wheel. This is the best theiry I can come up with as it definately solved the problem.
Old Feb 24, 2006 | 08:32 AM
Dugas's Avatar
Dugas
"Theory" that is..
Old Feb 24, 2006 | 07:13 PM
rickvulcan's Avatar
rickvulcan
Whitbeast97, Ford390gashog is right on the money. I changed my rear Differintial oil with the correct synthetic oil 75-140 however I did not use the friction modifier called for, I felt vibrations with every left turn . I did not know what was causing this problem. Steering gear box was bad, replaced it $325.00 did not correct the problem. Checked ball joints, tierods, c v joints and u joints. Re-read the manual (don't Forget Friction Modifier) 4.95 4oz. Smooth as a kitten. I guess you could say I over paid by 320.00.
Rick
Old Feb 28, 2006 | 01:46 PM
  #28
dmsman's Avatar
dmsman
Just to add something that I tried. I have a 2003 F150 SCREW and it was doing the same thing mainly on left turns. I had my tires rotated a month before, but not balanced. Well guess what, today I took it and had the tires rotated and balanced. All is good not sure if thats the same vibration that everyone else is talking about but sounded like it.
Hope this helps
Old Mar 17, 2006 | 12:58 PM
  #29
WhiteBeast97's Avatar
WhiteBeast97
Actually, I had replaced the left front half shaft by Les Schwab, sameday I noticed a bad vibration when I went over humps and took left turns, they didn't gimme a warranty either. I had Ford replace it again just recently and it solved the problem, I guess there are two different axels for my truck, Les Schwab must have put the wrong one on or something. A tech just put the rearend into my mind and I noticed there wasn't any LS additive in it.
Jco06
2009 - 2014 F150
18
Jun 12, 2016 10:15 AM
Ducati07
Jun 12, 2014 12:27 AM
Jeff396
Jul 22, 2012 09:20 PM
bintopo
Escape & Escape Hybrid
Jun 12, 2011 09:25 AM
jjmaas
Jun 14, 2010 02:26 PM
