temp sensor
Old Oct 31, 2001 | 03:50 AM
jbolf's Avatar
jbolf
temp sensor
I believe I have a 359-60-61 FT engine. I'm hooking up a new mechanical water temp guage. I would like to leave the factory guage in place and working. So, is there a second plug on these engines that I can use to put the water temp sensing bulb for my new meter??
Thanks
Jim
Old Oct 31, 2001 | 04:39 AM
BigBrownTruck's Avatar
BigBrownTruck
temp sensor
I have a thermastat housing on my 390 that has threaded plug in it that when removed is the right size for a temp sender. I put my mechanical sender into the intake manifold and then hooked up my electric sender to the thermastat housing. And then I found out that a local auto parts store has that same thermastat houseing for sale as a replacement part. I believe the FE and FT engines have interchangable thermastat houseings.
BBT
Old Oct 31, 2001 | 06:40 AM
jbolf's Avatar
jbolf
temp sensor
I will check that out when I get home from work. My engine has the dual thermostat housing so there should be plenty of room for something like that. Thanks for the tip. I'll let you know if I find something.
Thanks
Jim
Old Nov 1, 2001 | 05:27 AM
jbolf's Avatar
jbolf
temp sensor
[font size="1" color="#FF0000"]LAST EDITED ON 01-Nov-01 AT 06:29 AM (EST)[/font][p]Well, I checked and you are right. There is a large plug right in the middle of the dual thermostat housing. But it is huge, do you remember what size adaptor that you used?
Jim
Whoops!! Should have read you reply more carefully. Apparently your sensor fit the opening, mine won't. And I think that it is too big to fit in the intake manifold opening, so I will have to do more shopping around.
Thanks
Jim
Old Nov 1, 2001 | 03:39 PM
BigBrownTruck
temp sensor
Maybe you should check the plumbing supplies at your auto-parts or hardware store. I've seen many brass pipe thread adapters that perhaps would work.
BBT
Old Nov 2, 2001 | 03:48 AM
jbolf's Avatar
jbolf
temp sensor
I'll do that this weekend. Sheesh, wouldn't it be nice if the factory just installed decent mechanical meters in the first place?
Thanks for the help
Jim
Old Nov 2, 2001 | 10:12 AM
beartracks's Avatar
beartracks
temp sensor
