1992 F150 Speedometer not working
Old Sep 1, 2015 | 06:26 PM
iwals's Avatar
iwals
I have a 1992 F150 4.9L 6 cyl. 5 speed overdrive 2 wheel drive. The other day the speedometer suddenly stopped working and the odometer is blank. No burned out fuses that I could find. From a little research, it sounded like the speed sensor went bad, so I replaced it (located on differential). That didn't fix the problem.
I know I should have checked codes first. Well next I checked the ABS system codes. The test point was behind the glove box, contrary to what my Haynes book said. I found the connector with the black wire and orange stripe and grounded it with the ignition on. After about a second the ABS light comes on and stays on as long as it is grounded. Remove wire, light goes out, connect and it goes back on. Best I can tell it is sending no codes.
Also, this connector wasn't connected to anything, and I can't find another connector for it to mate to. I don't know what to make of that.
Any help would be greatly appreciated.
Old Sep 1, 2015 | 06:35 PM
rla2005's Avatar
rla2005
Blank odometer usually means Fuse 8 or 18 is bad. One is keep alive the other is hot with the key in Run position.
If both fuses are good then you have a bad PSOM.
Old Sep 9, 2015 | 11:17 AM
iwals's Avatar
iwals
I checked both fuses for continuity and checked for power at fuse box--they all checked out ok. So I guess I have a bad PSOM. Will replacing the speedometer fix this? I can actually get one with an odometer reading pretty close to what the truck has, so I don't have to worry about resetting it.
Old Sep 9, 2015 | 11:57 AM
rla2005's Avatar
rla2005
You can swap the PSOM from the donor to your truck. Since you have it apart verify you have power to the PSOM on Pins 1 and 3.
The ground is Pin 2
rabraker
1983 - 2012 Ranger & B-Series
23
Oct 21, 2019 05:47 PM
Nemz
Feb 3, 2016 07:38 PM
GrumpyTroy
Nov 15, 2015 01:44 PM
1993 f150 straight 6
Aug 5, 2011 07:47 AM
rgiven
Sep 26, 2004 10:59 AM
